[OpenLayers-Users] Problem with marker Georss on Google maps base
layer
Marcello Brunaldi
marcello.brunaldi at student.unife.it
Mon Feb 16 06:34:13 EST 2009
I have a problem with the display of the marker layer, because the
coordinates do not match
this is my code:
function init()
options={
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
numZoomLevels:18,
units: "m",
maxResolution: 156543.0339,
maxExtent: new OpenLayers.Bounds(-20037508,
-20037508,20037508, 20037508)
map = new OpenLayers.Map('map', options);
var myBaseLayer = new OpenLayers.Layer.Google("Google",
'sphericalMercator': true,
'maxExtent': new
OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34)
new1[0] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/blu.xml',
{'icon':color[0]} );
new1[1] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/rosso.xml',
{'icon':color[1]} );
new1[2] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/verde.xml',
{'icon':color[2]} );
new1[3] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/giallo.xml',
{'icon':color[3]} );
new1[4] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/marrone.xml',
{'icon':color[4]} );
new1[5] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/arancio.xml',
{'icon':color[5]} );
new1[6] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/celeste.xml',
{'icon':color[6]} );
new1[7] = new OpenLayers.Layer.GeoRSS( 'GeoRSS', 'georss/viola.xml',
{'icon':color[7]} );
map.addLayers([myBaseLayer,unesco]);
for (n=0; n < 8; n++)
map.addLayer(new1[n]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
loadsetmap();
map.addControl(new OpenLayers.Control.Permalink());
map.addControl(new OpenLayers.Control.MousePosition());
- I build the GeoRSS xml file, drawing from PostGIS database coordinates
"SELECT ST_AsText (the_geom)"
- The shape is inserted into the database type utm32 ED50.
- when loading from the same PostGIS database file in Geoserver, the wms
layer perfectly see that on the map!
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090216/2a02ea1d/attachment.html
