[OpenLayers-Users] GML and KML styleMap
goliah bianchimro at gmail.com
Tue Feb 17 04:45:57 EST 2009
Sorry, the code I posted previously contains a typo,
the actual code (still not working for KML) is here:
var symbolizer = OpenLayers.Util.applyDefaults(
        {fillColor:'red', fillOpacity: 0.4, strokeColor: "black"},
        OpenLayers.Feature.Vector.style["default"]);
styleMap = new OpenLayers.StyleMap({"default": symbolizer});
if(layertype == 'gml')
                overlay = new OpenLayers.Layer.GML("GML", filename,
{extractAttributes: true, styleMap: styleMap});
else if(layertype == 'kml')
                overlay = new OpenLayers.Layer.GML("GML", filename, {
                        projection: map.displayProjection,
                        styleMap : styleMap,
                        format: OpenLayers.Format.KML,
                        formatOptions: {
                                extractStyles: false,
goliah wrote:
> Dear list,
> I'm trying to load a layer from a local file, using a GML or KML format
> based on file extension, and applying the same styleMap in both cases.
> The following code only works for GML but not for KML format.
> The var filename is the file to load and the var layertype is the
> extension of the file.
> Any hint?
> Thanks a lot
> Mauro
> 		overlay = new OpenLayers.Layer.GML("GML", filename, {extractAttributes:
> 		overlay = new OpenLayers.Layer.GML("GML", opts['layer'], {
> 			formatOptions: {
View this message in context: http://n2.nabble.com/GML-and-KML-styleMap-tp2339910p2339913.html
