[OpenLayers-Users] WFS ProxyHost
Kai Behncke Kai-Behncke at gmx.de
Wed Feb 18 06:01:08 EST 2009
Dear Raphael,
I  had also some problems with the wfs proxy-host.
In my case it was because I wrote the code of the proxy-host on a Windows-Machine and loaded it on a linux-server, there were some problem with the word wraps then (maby by coincidence you have the same error). I solved it with a dos2unix-compilation at the unix-server.
> I'm starting to think why use Openlayers... this ProxyHost is a really
> bitch.
Well, sometimes, at the beginning, OpenLayers is not soooooo easy, but after a while and some steps of learning it really starts to make big fun.
So don`t give up :-)
Beste regards, Kai
> On Tue, Feb 17, 2009 at 2:25 PM, Arnd Wippermann
> <arnd.wippermann at web.de>wrote:
> >  Hi,
> > for local addresses you don't need a proxy host. To be sure, that your
> > local address is used I would use relative path.
> > OpenLayers.ProxyHost="/cgi-bin/proxy.cgi/?url="
> > and you can also try to load your WFS with relative path. Then the proxy
> > script is not used. Not 100% sure but only addresses, which begins with
> http
> > , use the proxy script.
> > // Layer WFS
> >                 wfs = new OpenLayers.Layer.WFS(
> >                 "Quadras WFS",
> >                 "/geoserver/wfs",
> >                 {typename: 'topp:quadra'},
> > If your WFS is now loaded, then there seems something wrong with your
> proxy
> > script or configuration. If not loaded, copy the WFS request from
> firebug
> > into the address bar of your browser, to be sure that the request send a
> > valid response.
> > Arnd Wippermann
> >  *Von:* users-bounces at openlayers.org
> [mailto:users-bounces at openlayers.org]
> > *Im Auftrag von *Raphael Saldanha
> > *Gesendet:* Dienstag, 17. Februar 2009 02:10
> > *An:* users at openlayers.org
> > *Betreff:* [OpenLayers-Users] WFS ProxyHost
> > Hi!
> > I'm having some troubles on trying to use WFS...
> > As suggested in the FAQ, and put the proxy.cgi on cgi-bin Apache folder,
> > and add the line "AddHandler python-cgi-script .cgi" on httpd.conf, as
> > suggested in http://gist.fas.harvard.edu/chgis/?p=14.
> > But loading the following page, I receive the error 1012, on Firebug.
> > Help please!!!
> > <html>
> >     <head>
> >         <title>IPTU</title>
> >         <link rel="stylesheet" type="text/css" href="
> > http://localhost:8080/geoserver/openlayers/theme/default/style.css"/>
> >         <!-- Import OpenLayers, reduced, wms read only version -->
> >         <script src="
> > http://localhost:8080/geoserver/openlayers/OpenLayers.js"
> > type="text/javascript"></script>
> >         <script defer="defer" type="text/javascript">
> >             var map;
> >             var quadra;
> >             var imagem;
> >             var wfs;
> > http://localhost:8080/cgi-bin/proxy.cgi/?url=";
> >             // pink tile avoidance
> >             OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;
> >             // make OL compute scale according to WMS spec
> >             OpenLayers.DOTS_PER_INCH = 25.4 / 0.28;
> >             function init(){
> >                 format = 'image/png';
> >                 var bounds = new OpenLayers.Bounds(
> >                     497839.91636617144, 7649918.889418672,
> >                     499243.91636617144, 7650565.389418672
> >                 var options = {
> >                     controls: [],
> >                     maxExtent: bounds,
> >                     maxResolution: 5.484375,
> >                     projection: "EPSG:32723",
> >                     units: 'm'
> >                 map = new OpenLayers.Map('map', options);
> >                 // Layer QUADRA
> >                 quadra = new OpenLayers.Layer.WMS(
> >                     "Quadras", "http://localhost:8080/geoserver/wms",
> >                         layers: 'topp:quadra',
> >                         transparent: "true",
> >                         format: "image/png",
> >                         srs: 'EPSG:32723',
> >                         height: '345',
> >                         width: '800',
> >                         styles: '',
> >                         tiled: 'true',
> >                         tilesOrigin :
> > "497839.91636617144,7649918.889418672"
> >                 // Layer WFS
> >                 "Quadras WFS",
> >                 "http://localhost:8080/geoserver/wfs",
> >                     typename: 'quadra',
> >                     featureNS: 'http://www.openplans.org/topp',
> >                     extractAttributes: false
> >                 //Layer IMAGEM
> >                 imagem = new OpenLayers.Layer.WMS(
> >                     "WorldView-1",
> >                         layers: 'topp:lavras',
> >                         srs: 'EPSG:32723',
> >                         height: '345',
> >                         width: '800',
> >                         styles: '',
> >                         format: format,
> >                         tiled: 'true',
> >                         tilesOrigin :
> >                 map.addLayers([quadra,wfs,imagem]);
> >                 // build up all controls
> >                 map.addControl(new OpenLayers.Control.PanZoomBar({
> >                     position: new OpenLayers.Pixel(2, 15)
> >                 map.addControl(new OpenLayers.Control.Navigation());
> >                 map.addControl(new OpenLayers.Control.LayerSwitcher());
> >                 map.zoomToExtent(bounds);
> >         </script>
> >     </head>
> >     <body onload="init()">
> >         <div id="map">
> >         </div>
> >     </body>
> > </html>
> > Regards,
> > Raphael Saldanha
> > saldanha.plangeo at gmail.com
> Atenciosamente,
> Raphael Saldanha
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
