[OpenLayers-Users] Scoping Issue With Yahoo Geocoder
Matt Kenny matthewkenny at gmail.com
Thu Feb 19 15:23:54 EST 2009
Wow, it worked perfectly. Thank you! I really appreciate your help
Sebastian. At my current skill level with JS, I know enough to recognize
these problems, but still need advice in coming up with solutions. Another
piece of knowledge filed away.
take care,
matt
On Thu, Feb 19, 2009 at 9:53 AM, Sebastian Benthall <seb at opengeo.org> wrote:
> On Wed, Feb 18, 2009 at 3:32 PM, Matt Kenny <matthewkenny at gmail.com>wrote:
>> Hello Everyone,
>> I'm having some trouble passing an array of properties to points created
>> with the yahoo geocoder control:
>> http://trac.openlayers.org/attachment/ticket/1784/yahoogeocoder.html
>> I've got a series of address stored in a MySQL database, each of which
>> also have a 'NAME' property associated with an ambulance company. I'm using
>> a php script to create a javascript variable which extracts all of these
>> values from the database. A simple looping function then runs each of them
>> through the yahoo geocoder
>> The resulting points are geocoded in the correct location, but attributing
>> these geocoded points with their respective 'NAME' values is turning out to
>> be an issue. Each geocoded point is being attributed with the 'NAME' value
>> for the last row in the array. I 'believe' that the issue is related to
>> scoping. I 'know' that the issue is related to my knowledge of javascript,
>> and any help would be greatly appreciated.
>> I've got a live example running at:
>> http://www.mkgeomatics.com/apps/air_ambulance/aab_embed_test.php
>> Clicking on the ambulance markers will yield the result which I have
>> described above.
>> The geocoding function for the ambulance companies begins at line 333,
>> geocodeGroundAmbulance().
>> The callback function begins at line 358, callbackGroundAmbulance().
>> Finally, the ID function begins at line 298, IdGroundAmbulance(feat).
>> Thanks in advance for any tips or suggestions.
>> m a t t h e w k e n n y
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Hi Matt,
> Yes, this looks like a scoping error to me.
> The problem is that within the geocodeGroundAmbulance() function, the main
> loop that sets the groundAmbulance variable finishes before the callback
> function to the response is called.  So when the function is called, the
> value of groundAmbulance has been set to the last item in the array.
> One solution would be to build the callback within a separate function,
> which would put the variable in a different scope.  What I mean is something
> like:
> var makeCallback = function(ga){
>   return function(response){
>     callbackGroundAmbulance(response, ga);
>  ygc.getLocation(query, makeCallback(groundAmbulance))
> There may be a more elegant solution, but I think this should do the trick.
> It's great to see somebody use that geocoder!  It reminds me that I should
> do the legwork to make it a proper addin.  If you have any other feedback on
> it, I'd love to hear it.
> Sebastian Benthall
> OpenGeo - http://opengeo.org
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090219/9b47f26f/attachment.html
