[OpenLayers-Users] proxy not working
Ivan Grcic igrcic at gmail.com
Mon Feb 23 06:22:49 EST 2009
Yup might be something about IIS. Seems that proxy is set up fine, and
geoserver is working ok.
But when you run
http://84.205.237.73/script/proxy.py?url=http://84.205.237.73:443/geoserver/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=application%2Fvnd.ogc.se_xml&BBOX=142.52861%2C-44.59531%2C149.785355%2C-38.626637&X=567&Y=316&INFO_FORMAT=text%2Fhtml&QUERY_LAYERS=tasmania&FEATURE_COUNT=50&Layers=tasmania&Styles=&Srs=EPSG%3A4326&WIDTH=800&HEIGHT=658&format=image%2Fpng
you get:
Some unexpected error occurred. Error text was: <urlopen error [Errno
10060] A connection attempt failed because the connected party did not
properly respond after a period of time, or established connection
failed because connected host has failed to respond>
What does ur IIS log say? Sorry but dont know much about IIS, always
used apache or in J2EE environment.
Maybe here are some users that set it up on IIS??
2009/2/23 Mika Lehtonen <mika at digikartta.net>:
> Hi George,
> maybe you indeed need a proxy. You are running your servers in a same host,
> but in different ports, right? I'm not an expert on this, but I think that's
> the case. From the proxy point of view, they're not a same host.
> I am still thinking that this could be an IIS related problem. I tried your
> proxy and it seemed to be working when accessing openlayers.org or
> openstreetmap.org. But when I tried to access your server (Jetty?), I get
> these:
> Some unexpected error occurred. Error text was: <urlopen error [Errno 10060]
> A connection attempt failed because the connected party did not properly
> respond after a period of time, or established connection failed because
> - mika -
> P.S. I think you could also set some proxy up in your IIS so that e.g. all
> the requests made to host/geoserver/ would redirect to host:443/ or
> something like that..
> george gpoul48 kirjoitti:
> It is working without proxy only in localhost, but not from the internet.
> That is why i used proxy. Is it possible to run without proxy? Regarding iis
> i have no idea what it should be. IIS configured and tested to run python
> without problem. Any idea?
> thank you all for your concern
> ________________________________
> Date: Mon, 23 Feb 2009 11:02:36 +0200
> From: mika at digikartta.net
> To: igrcic at gmail.com
> CC: gpoul48 at hotmail.com; users at openlayers.org
> Subject: Re: [OpenLayers-Users] proxy not working
> Hi Ivan and George,
> I just tested the site and it seems that the request sent works. Also the
> proxy works. But do you need proxy when using GetFeatureInfo?
> maybe this has something to do with IIS?
> - mika -
> Ivan Grcic kirjoitti:
> Hi,
> first check if the normal request is working, without proxy. What does
> firebug say if its not working?
> On Mon, Feb 23, 2009 at 9:26 AM, george gpoul48 <gpoul48 at hotmail.com> wrote:
> Hallo everyone!!
> I use this proxy.py file and i am trying to get information for a map
> feature clicking on it, but the computer returns this message:
> "Some unexpected error occurred. Error text was:"  Can anyone help me? Where
> am i wrong?
> See my map at http://84.205.237.73/default/mytest.aspx
> Proxy.py code
> #!C:/Python26/python.exe -u
> import urllib2
> import cgi
> import sys, os
> # Designed to prevent Open Proxy type stuff.
> allowedHosts = ['84.205.237.73:443', 'www.openlayers.org', 'openlayers.org',
>                 'labs.metacarta.com', 'world.freemap.in',
>                 'prototype.openmnnd.org', 'geo.openplans.org',
>                 'sigma.openplans.org',
>                 'www.openstreetmap.org']
> method = os.environ["REQUEST_METHOD"]
> if method == "POST":
>     qs = os.environ["QUERY_STRING"]
>     d = cgi.parse_qs(qs)
>     if d.has_key("url"):
>         url = d["url"][0]
>     else:
>         url = "http://www.openlayers.org"
> else:
>     fs = cgi.FieldStorage()
>     url = fs.getvalue('url', "http://www.openlayers.org")
> try:
>     host = url.split("/")[2]
>     if allowedHosts and not host in allowedHosts:
>         print "Status: 502 Bad Gateway"
>         print "Content-Type: text/plain"
>         print
>         print "This proxy does not allow you to access that location (%s)."
> % (host,)
>         print
>         print os.environ
>     elif url.startswith("http://") or url.startswith("https://"):
>             length = int(os.environ["CONTENT_LENGTH"])
>             headers = {"Content-Type": os.environ["CONTENT_TYPE"]}
>             body = sys.stdin.read(length)
>             r = urllib2.Request(url, body, headers)
>             y = urllib2.urlopen(r)
>         else:
>             y = urllib2.urlopen(url)
>         # print content type header
>         i = y.info()
>         if i.has_key("Content-Type"):
>             print "Content-Type: %s" % (i["Content-Type"])
>         else:
>         print
>         print y.read()
>         y.close()
>     else:
>         print
>         print "Illegal request."
> except Exception, E:
>     print "Status: 500 Unexpected Error"
>     print
>     print "Some unexpected error occurred. Error text was:", E
> getfeatureinfo code
> OpenLayers.ProxyHost = "/script/proxy.py?url=";
> map.events.register('click', map, function (e) {
>                     document.getElementById('nodelist').innerHTML = "Please
> wait...";
>                     var params = {
>                         REQUEST: "GetFeatureInfo",
>                         EXCEPTIONS: "application/vnd.ogc.se_xml",
>                         BBOX: map.getExtent().toBBOX(),
>                         X: e.xy.x,
>                         Y: e.xy.y,
>                         INFO_FORMAT: 'text/html',
>                         QUERY_LAYERS: map.layers[0].params.LAYERS,
>                         FEATURE_COUNT: 50,
>                         Layers: 'Tinos:dimoi',
>                         Styles: '',
>                         Srs: 'EPSG:900913',
>                         WIDTH: map.size.w,
>                         HEIGHT: map.size.h,
>                         format: format};
> OpenLayers.loadURL("http://84.205.237.73:443/geoserver/wms", params, this,
> setHTML, setHTML);
>                     OpenLayers.Event.stop(e);
>             // sets the HTML provided into the nodelist element
>             function setHTML(response){
> response.responseText;
> Κάντε κλικ για να παίξετε Fishticuffs με τους φίλους σας, τώρα! Κάντε κλικ
> εδώ!
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Φέρτε τους φίλους σας από το Facebook και το Hotmail στον Messenger ΤΩΡΑ!
> Κάντε κλικ εδώ!
> Users mailing list
> Users mailing list
Ivan Grcic
