[OpenLayers-Users] Inducing LayerSwitcher to Update Through Programming
Bill Thoen bthoen at gisnet.com
Mon Feb 23 11:28:53 EST 2009
I've got a javascript application that changes the base layer of a map
as one of its operations and I was wondering what the most correct way
to update the LayerSwitcher control to reflect the changed base layer
would be. In LayerSwitcher.js I didn't see an obvious function like
setBaseLayer() or similar, and redraw() alone doesn't react to a changed
base layer. So what I did was set layerStates.length = 0 and called
redraw(). This works, but I was wondering if this is the best way to
handle it?
- Bill Thoen
