[OpenLayers-Users] Handling of empty getFeatureInfoResults
Kai Behncke Kai-Behncke at gmx.de
Tue Feb 24 06:02:22 EST 2009
Hello list,
I found a solution now via OpenLayers.Request.GET.
If somebody else might have the same problem, it works well with that code;
    map.events.register('click', map, function (e) {
 	            var url =  wms.getFullRequestString({
 	                            REQUEST: "GetFeatureInfo",
 	                            EXCEPTIONS:
                                    "application/vnd.ogc.se_xml",
	                            BBOX: wms.map.getExtent().toBBOX(),
 	                            X: e.xy.x,
 	                            Y: e.xy.y,
 	                            INFO_FORMAT: 'text/html',
	                            QUERY_LAYERS: wms.params.LAYERS,
                              WIDTH: wms.map.size.w,
 	                            HEIGHT: wms.map.size.h});
 	function handler(request) {
    answer=request.responseText.length;
	if (answer==1) {
url=special_url_for_no_results;
 new_window(url);
 	 }else {
   new_window(url);
var request = OpenLayers.Request.GET({
    url: url,
    callback: handler
Best regards, Kai
-------- Original-Nachricht --------
> Datum: Mon, 23 Feb 2009 17:32:51 +0100
> Von: "Kai Behncke" <Kai-Behncke at gmx.de>
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] Handling of empty getFeatureInfoResults
> Dear list,
> I have got a question to the handling of "empty" getfeatureinfo-results.
> The "core" of getfeatureinfo.html (in the examples) is:
>                             EXCEPTIONS: "application/vnd.ogc.se_xml",
>                             X: e.xy.x,
>                             Y: e.xy.y,
>             OpenLayers.loadURL(url, '', this, setHTML);
>             OpenLayers.Event.stop(e);
>     function setHTML(response) {
>         OpenLayers.Util.getElement('nodeList').innerHTML =
> response.responseText;
> It works nice if I click on an existing wms-point.
> I wonder how to handle a empty "non-existing-response" (that comes if I
> click beside a wms-point).
> I try to write a function (new_window(url)) that opens a new window with
> an entry "You clicked besides the point" (or, if not, the result of the
> wms-point).
> like :
>  	   function setHTML(response,url) {
>  	//"non existing response" -> click besides a point
>  	if (response.responseText.length==1) {
>  	  url='http://noresult_url';
>          new_window(url);
> //response -> click on a point
> else
>     new_window(url);
> But the problem is: I don`t get it to transport the url to the function
> "setHTML", so that setHTML works with that ajax-response AND(!) the url.
> Has anybody an idea how to solve/handle that?
> Thank you very much, Kai
> Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen:
> http://www.gmx.net/de/go/multimessenger01
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
