[OpenLayers-Users] Inducing LayerSwitcher to Update Through
Programming
Christopher Schmidt
crschmidt at metacarta.com
Tue Feb 24 13:27:36 EST 2009
On Tue, Feb 24, 2009 at 11:07:19AM -0700, Bill Thoen wrote:
> Christopher Schmidt wrote:
> >>>map.setBaseLayer(map.layers[1])
> >>>on http://openlayers.org/dev/examples/controls.html cause the
> >>>ayerSwitcher to redraw for me. Does it not do that for you? It should;
> >>>if it doesn't, that's a bug.
> >>Here's an example where a layer is switched under the LayerSwitcher's
> >>nose, and it doesn't react to it even if you call setBaseLayer() after
> >>the change: http://206.168.217.244/gallery/ToggleBaseLayer.html
> >setBaseLayer after the layer is *already* visible won't do anything,
> >that is correct. That's not how setBaseLayer is designed to be used.
> >Though this exposes a behavior in the LayerSwitcher, I don't think it's
> >a bug, because this demonstration seems a bit like an anti-use of the
> >library.
> >>I realize that if I had called setBaseLayer() first I wouldn't have to
> >>go through all that bit to change layer visibilities, but this "bug"
> >>appeared as a result of originally wanting to change overlay layers.
> >Overlay layers should react to setVisibility -- something that base
> >layers do differently. Can you find an overlay layer whiwch doesn't do
> >the right thing if you setVisiblity on it (via the method, rather than
> >via layer.visibility and layer.redraw() or somethign like that)?
> No, setVisibility works as advertised on all overlay layers. This was
> what I was focused on to begin with, and I was updating the property
> because I didn't know any better (I'm still on the steep part of the
> learning curve with this library.) It was only after I had done it that
> I realized that the base layers were not being handled. So I tinkered
> with the LayerSwitcher innards even more, but finally decided I was
> going about this all wrong and hence my original question about what's
> the right way. One problem for beginner JavaScript programmers like me
> is that since everything is exposed, you're tempted to grab at the first
> thing that looks good. Its sort of like giving a monkey the keys to the
> banana plantation. I agree with you that calling setBaseLayer after I've
> set visibility is a mistake, but because setBaseLayer didn't work as
> expected in this case, I wondered if I should call attention to it anyway.
Yep. I would say that this is perhaps worth documenting, but is
definitely a rare case.
For teh record, the difference between:
http://dev.openlayers.org/apidocs/
and
http://dev.openlayers.org/docs/
Sort of acts a set of "Here's what you can monkey with safely". (It's
not perfect, because the actual intention is "This won't change", but
the result is pretty similar.)
Best Regards,
Christopher Schmidt
MetaCarta
