[OpenLayers-Users] drawing style
Tim Schaub tschaub at opengeo.org
Wed Feb 25 14:32:03 EST 2009
Hey-
So, we've long defined a "temporary" style for vector features.  This is
a symbolizer that is used to create an OpenLayers.Style object keyed by
the "temporary" rendering intent in the default StyleMap given to all
vector layers.
http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Feature/Vector.js#L378
This is a symbolizer that was put together without much thought.  It is
a garish yellow line, 4 pixels wide.  Nobody probably saw it used before.
I just put in a change that passes the style associated with the
temporary rendering intent to the sketch handlers.  The effect is that
this default symbolizer is now used when drawing new sketches.
So, if you didn't explicitly change your temporary feature style before,
you used to get the partially transparent orange.  Now you get thick
yellow strokes.
This makes things a bit uglier by default (in my opinion).  We've got a
couple options:
1) Make the temporary style the same as the default style.  This would
give people what they had before (partially transparent orange sketches).
2) Make the temporary style something else.  This would change the look
of applications where people were using the defaults.  (And we could
post some options and for people to weigh in on.)
Any opinions?
Tim
See the temporary yellow style here:
http://openlayers.org/dev/examples/select-feature.html
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
