[OpenLayers-Users] Sizing background images and StyleMaps
Ivan Grcic ivan.grcic at geofoto.hr
Thu Feb 26 16:09:09 EST 2009
externalGraphic
    An external image to be used to represent a point.
graphicWidth, graphicHeight
    These properties define the height and width of an
externalGraphic. This is an alternative to the pointRadius symbolizer
property to be used when your graphic has different sizes in the X and
Y direction.
graphicOpacity
    Opacity of an external graphic.
graphicXOffset, graphicYOffset
    Where the ‘center’ of an externalGraphic should be.
graphicName
    Name of a type of symbol to be used for a point mark.
cheers
On 2/26/09, Nicholas Bergson-Shilcock <nicholasbs at openplans.org> wrote:
> Excerpts from Christopher Schmidt's message of Thu Feb 26 12:26:38 -0500
> 2009:
>> On Thu, Feb 26, 2009 at 12:16:05PM -0500, Nicholas Bergson-Shilcock wrote:
>> > Hello,
>> > I'm pretty new to OpenLayers and I have a couple of questions.
>> > 1) How can I set the size of a background graphic? I'm doing something
>> > similar
>> > to the marker shadow example here[1]. I guessed and used
>> > graphicWidth/graphicHeight to set the size of my marker image (which
>> > works),
>> > but neither backgroundGraphicWidth nor backgroundWidth seem to have any
>> > effect
>> > on my shadow image. What's the correct way to do this?
>> > 2) Is there a place to look up all of the options for an
>> > OpenLayers.StyleMap
>> > object?
>> http://docs.openlayers.org/library/feature_styling#style-properties
> Ah, thanks for pointing me towards these. This is just the type of doc  I
> was
> looking for, however, I don't see any options relating to background images.
> Do
> you know if it's possible to explicitly set the size of a background image?
> Thanks for the help and a great product,
>   -Nick
>> Regards,
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ivan Grcic
