[OpenLayers-Users] feature.geometry does not exist
Christopher Schmidt crschmidt at metacarta.com
Thu Feb 26 20:51:23 EST 2009
On Fri, Feb 27, 2009 at 02:31:46PM +1300, Robert Connolly wrote:
> Hi Everyone,
> I'm attempting to read some features from a GeoJSON encoded object
> transform them for the correct projection and add them to a vector
> layer, like so:
> var feature = geojson_format.read(data[j]);
> feature.geometry.transform(new OpenLayers.Projection("EPSG:4326"),
> map.getProjectionObject());
http://dev.openlayers.org/apidocs/files/OpenLayers/Format/GeoJSON-js.html#OpenLayers.Format.GeoJSON.read
"The return depends on the value of the type argument.  If type is
“FeatureCollection” (the default), the return will be an array
of OpenLayers.Feature.Vector."
feature[0].geometry.transform
Regards,
Christopher Schmidt
MetaCarta
