[OpenLayers-Users] Looping through unique markers?
David Raasch
dr4296 at myoldhouse.com
Fri Feb 27 12:35:06 EST 2009
OK, I discovered where apparently, this is known to happen when using Vector
layers. And I had forgotten to comment-out my Vector layer completely when
switching over to using a Marker layer instead. So, I've got that part of
it solved.
That leaves me with:
1) How to get each marker to have its own unique function? ( I know right
now it's just an "alert", but I plan on making that function trigger a
pop-up with some marker-specific HTML code in it in the near future).
2) Why do none of the markers (or the circle, for that matter) display in
Firefox?
Thanks!
-= Dave =-
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of David Raasch
Sent: Friday, February 27, 2009 10:44 AM
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] Looping through unique markers?
Hmmm... I just realized that if I go to the map controls and turn off the
circle and vector layers, then the events work for all icons, in the sense
that they all activate an "alert" pop-up. Of course, the trouble is, all
alerts say exactly the same thing, basically showing the text for point #571
only.
So, it looks like I've got two problems: Why is it that the Vector and
Circle layers seem to be "interfering" with the click events? And
apparently I have to figure out how to give each registered event instance a
reference to its own unique "evt" function.
-= Dave =-
Sent: Friday, February 27, 2009 8:13 AM
Subject: [OpenLayers-Users] Looping through unique markers?
Greetings All!
When I posted to the list last week, I had coded my little app to use
FEATURES to draw marker icons and rig-up word-balloon pop-ups whenever they
were clicked-on.
However, the markers took a very, very long time to load. So, digging
further into the archives of this discussion list, I discovered that,
although using MARKERS to draw marker icons is considered to be "the old way
of doing it", that way is apparently faster.
So, I set about commenting-out the feature-adding/drawing lines in my code
and inserting some lines that would loop through my array of data, draw
each marker, and register an event for that marker.
My problem is that I'm only getting the event to work on the FINAL marker in
the array.
I've posted my files here:
http://www.davidraasch.com/ww/map_v4.html
If you zoom in over that cluster near Chicago and click, eventually you'll
trigger an alert message on the one marker, which is the last one in the
array. It will say "You clicked on marker m571".
Feel free to do a "view source", but here are the pertinent lines from my
code:
var markers_layer = new OpenLayers.Layer.Markers( "Markers Layer");
map.addLayer(markers_layer);
var xml_points =
xmlDoc.documentElement.getElementsByTagName("point");
var m = [];
for (var i = 0; i < xml_points.length; i++)
var type =
xml_points[i].getAttribute("type");
var thislat =
(parseFloat(xml_points[i].getAttribute("lat")));
var thislng =
(parseFloat(xml_points[i].getAttribute("lng")));
var html =
xml_points[i].getAttribute("html");
{to reduce "noise" here for you, I'm leaving out the if-then statements that
determine which exact icon graphic file to use, plus its height and width }
// Code to push each point as a MARKER LAYER MARKER
var size = new
OpenLayers.Size(icon_width,icon_height);
var offset = 0; // new
OpenLayers.Pixel(-(icon_width/2), -icon_height);
var icon = new
OpenLayers.Icon(icon_image,size,offset);
m[i] = new OpenLayers.Marker((new
OpenLayers.LonLat(thislng,thislat).transform(new
OpenLayers.Projection("EPSG:4326"), map.getProjectionObject())),icon);
markers_layer.addMarker(m[i]);
m[i].events.register ('click',
m[i], function(evt) {alert ('You clicked on marker m'+ i);
OpenLayers.Event.stop (evt); })
// alert("i="+ i);
} // end of "for i = 0 to all POINTS
(Originally, I was using just the variable "m1" to represent the markers, as
taken from an example I found somewhere on the openlayers.org site. But
then, in debugging it, I switched to using "m" as an array, just to make
sure I did understand what we're trying to do here.)
I should also mention that, for some reason, the markers don't even appear
to load in Firefox! I can only see them in IE. ????
Any thoughts?
Thanks!
-= Dave =-
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.11.3/1974 - Release Date: 02/26/09
14:51:00
Users mailing list
14:51:00
