[OpenLayers-Users] Change server wms layer depending resolution
Vidal, Antoni antoni.vidal at icc.cat
Fri Jan 2 10:16:22 EST 2009
Yes, This is that I want, but I have three base layer and I only want
this for one of them.
I actually have:
var topo = new OpenLayers.Layer.WMS(
		    _("Topographic"), baseWmsServer,
			{layers: 'topo', format:"image/jpeg",
exceptions:"application/vnd.ogc.se_xml"},
	        	{buffer:0, transitionEffect:'resize'}
How can I implement two scale-dependant WMS overlays like you propose?
Thank's in advance,
Antoni Vidal.
-----Mensaje original-----
De: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Enviado el: viernes, 02 de enero de 2009 16:04
Para: Vidal, Antoni
CC: users at openlayers.org
Asunto: Re: [OpenLayers-Users] Change server wms layer depending
resolution
On Fri, Jan 02, 2009 at 02:39:23PM +0100, Vidal, Antoni wrote:
> Hi there,
> I would change the server of a wms layer depending of map's
resolution. Is this possible ?, if yes, any help will be thankfull.
You probably want to have two scale-dependant WMS overlays -- one with a
minScale: 1000000, maxScale: 10000 , the next with a minScale: 10000 ,
maxScale: 1, or something. If you don't have another base layer,
creating an empty base layer:
  new OpenLayers.Layer("", {displayInLayerSwitcher: false, isBaseLayer:
  true});
Can be used.
REgards,
Christopher Schmidt
MetaCarta
