[OpenLayers-Users] RS: Change server wms layer depending resolution
Vidal, Antoni
antoni.vidal at icc.cat
Fri Jan 2 17:22:53 EST 2009
Thank's David.
You know any example code how to implement a scale-dependent WMS layer?.
Thank's again.
Antoni Vidal.
-----Missatge original-----
De: David Fawcett [mailto:david.fawcett at gmail.com]
Enviat el: dv. 02/01/2009 16:56
Per a: Vidal, Antoni
A/c: users at openlayers.org
Tema: Re: [OpenLayers-Users] Change server wms layer depending resolution
Antoni,
If you also control the WMS and are serving up your own data, you
could use a scale-dependent WMS layer as your source.
You could also potentially build a WMS layer that cascades the data
from the two external WMS', using scale to determine which data source
to use. That said, this would likely be a performance hit, you would
probably do better to write some custom javascript code to accomplish
it on the client side.
David.
On Fri, Jan 2, 2009 at 7:39 AM, Vidal, Antoni <antoni.vidal at icc.cat> wrote:
> Hi there,
> I would change the server of a wms layer depending of map's resolution. Is
> this possible ?, if yes, any help will be thankfull.
> Happy 2009.
> Antoni Vidal
> Institut Cartogràfic de Catalunya Tel: +34-93 567 1500 Ext. 3228
> Parc de Montjuïc Fax: +34-93 567 1567
> 08038 Barcelona http://www.icc.cat
> Spain
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090102/62b78624/attachment.html
