[OpenLayers-Users] OpenLayers Google Map resolution Issue
Eric Lemoine
eric.c2c at gmail.com
Mon Jan 5 01:45:13 EST 2009
Hi
>From my understanding you can't change the resolution numbers of
commercial layers. I'm not very familiar with the commercial APIs so
I'd like to be corrected if I'm wrong.
Cheers,
Eric
2008/12/30, AJ R <ajayr.email at gmail.com>:
> Hi
> I am trying to do an interesting thing.
> I have couple of user defined WMS layers (in EPSG 32616) which have a
> set of resolutions not matching the Google Resolutions. I was trying
> to modify the Google layer to match the resolution set that I have (I
> had to tweak the OpenLayers code for this). The Google Layer was able
> to get me the right zoom for the resolution, but when doing the
> calculateBounds() in the Map object, the WMS layer extent (of course
> they have been reprojected to 900913) are slightly skewed i.e. does
> not match the bounding box extent in my Context document.
> I found the reason for this and that is the way calculateBounds()
> tries to find the extent from the center, which skews the extent a
> little bit as compared to the default extent. Does anyone have any
> idea why this happens. Does this mean that we cannot change the
> default resolution set for the google / yahoo maps?
> Any information would be helpful
> Thanks & regards
> Ajay Ravichandran
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
