[OpenLayers-Users] custom control.button problems
Eric Lemoine eric.c2c at gmail.com
Mon Jan 5 12:06:33 EST 2009
Hi
You don't pass a function in the options but the return code of a function.
Try this:
var onTrigger = function() {
    alert("yo");
var btn = new OpenLayers.Control.Button({
    trigger: onTrigger
Cheers,
Eric
2009/1/5, David Hollema <dhollema at unitedpower.com>:
> Couple question as an openlayers newbie.
> * I can't get custom control.buttons to fire.  What am I doing wrong?  I
> tried in IE7 and FF and neither work properly.
> * When I first open the web page, the functions which are assigned to
> the trigger events of my custom control buttons are fired.  What's going
> on here?  This function below gets called during the body onload of the
> html.  I don't see why it's calling the trigger events are called.
> 		function init(){
> 				/*var options = {
>                     controls: [new OpenLayers.Control.MouseDefaults()],
> units: 'ft'
> 				var options = {
>                     units: 'ft'
> 					//projection: "EPSG:4326"
> 				map = new OpenLayers.Map('map' ,
> options);
> document.getElementById('IDimgFolder').value = baseURL;
> 				setImgArray();
> 				/*var wms = new OpenLayers.Layer.WMS(
>                     "OpenLayers WMS",
>                     "http://labs.metacarta.com/wms/vmap0?",
>                     {layers: 'basic'}
>                 //map.addLayer(wms);
> 				//debugger;
> 				pointLayer = new
> OpenLayers.Layer.Vector("Target Picks", {geometryType:
> OpenLayers.Geometry.Point});
> 				map.addLayer(pointLayer);
> 				//debugger;
> 				//OpenLayers.ProxyHost="/proxy/?url=";
> 				//var newl = new OpenLayers.Layer.Text(
> "text", {location: "test.txt"} );
> "text", {location: "http://openlayers.org/dev/examples/textfile.txt"} );
> "text", {location: "c://temp//test.txt"} );
> 				//map.addLayer(newl);
> 				//var new2 = new OpenLayers.Layer.GML(
> "textGML", "http://upigis/joint use/test.txt",{format:
> OpenLayers.Format.Text});
> 				//map.addLayer(new2);
>                 var new3 = new OpenLayers.Layer.GML( "Target Picks GML",
> "http://upigis/joint use/point.xml");
> 				map.addLayer(new3);
> 				//map.setLayerIndex(new3, 0);
> 				map.setCenter(0,0);
> 				map.addControl(new
> OpenLayers.Control.MousePosition({div:
> document.getElementById("mouseposition"),
> 				prefix: "mouse pos:  (", suffix: ")"}));
> 				map.addControl(new
> OpenLayers.Control.PanZoom());
> 				map.addControl(new
> OpenLayers.Control.LayerSwitcher());
> 				var overview = new
> OpenLayers.Control.OverviewMap();
> 				map.addControl(overview);
> 				var panCustom = new
>                     {title:'You can use the default mouse
> configuration'});
> 				var zb = new OpenLayers.Control.ZoomBox(
>                 {title:"Zoom box: Selecting it you can zoom on an area
> by clicking and dragging."});
> 				var drawPtControl = new
> OpenLayers.Control.DrawFeature(pointLayer,
>                                 OpenLayers.Handler.Point, {title:'Pick
> target on photo'});
> 				var dragPtControl = new
> OpenLayers.Control.DragFeature(pointLayer, {title:'Move target pick'});
> 				//map.addControl(dragPtControl);
> 				var history = new
> OpenLayers.Control.NavigationHistory();
> 				map.addControl(history);
> 				var clearPicksBtn = new
> OpenLayers.Control.Button({trigger: clearPicks(pointLayer),
> displayClass: "clearPicksBtn",
> 				title:'Clear all picks'});
> 				var prevPhotoBtn = new
> OpenLayers.Control.Button({trigger: f_slideshow(-1), displayClass:
> "prevPhotoBtn",
> 				title:'Previous photo'});
> 				var nextPhotoBtn = new
> OpenLayers.Control.Button({trigger: f_slideshow(1), displayClass:
> "nextPhotoBtn",
> 				title:'Next photo'});
> 				//var panel = new
> OpenLayers.Control.Panel({div: document.getElementById("panel")});
> 				var panel2 = new
> OpenLayers.Control.Panel({div: document.getElementById("panel2"),
> defaultControl: panCustom});
> 				panel2.addControls([panCustom, zb,
> history.next, history.previous, drawPtControl,
> 				dragPtControl, clearPicksBtn,
> prevPhotoBtn, nextPhotoBtn]);
> 				map.addControl(panel2);
> David A. Hollema
> GIS Analyst
> United Power, Inc.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
