[OpenLayers-Users] What's the Difference Between feature.data
and feature.attributes?
Eric Lemoine
eric.c2c at gmail.com
Mon Jan 5 12:15:15 EST 2009
Hi
For information "data" is in the base Feature class while "attributes"
is in the Feature.Vector class. "data" is there for historical reason
and isn't to be used when using Feature.Vector, so you should use
"attributes". This is particularly true if you're to use a Format to
serialize features, or to style your features based on property
values.
Eric
2009/1/5, Bill Thoen <bthoen at gisnet.com>:
> I want to create some points in a vector layer and associate some data
> values with them. It looks like I could store them in either the point
> feature's data object or its attributes object. Which should I use and
> what's the difference between these feature objects?
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
