[OpenLayers-Users] Layer.Vector with multiple data sources
Andreas Hocevar ahocevar at opengeo.org
Fri Jan 9 10:22:42 EST 2009
Arnd,
On Fri, Jan 9, 2009 at 2:37 PM, Arnd Wippermann <arnd.wippermann at web.de> wrote:
> I have no luck so far.
> The following code is from the example styles-context.html, added the
> getVisibility. If you paste the code into firebug console for the openlayers
> homepage http://openlayers.org/, it will add a vector layer with points. At
> zoomLevel 0 the red points are set to display:"none", etc.
> But you can see, that the display property have no effect. Do I miss
> something?
On the contrary! You have found a bug. See
http://trac.openlayers.org/ticket/1898 for a fix.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
