[OpenLayers-Users] Best Practice
Alexandre Dube
adube at mapgears.com
Mon Jan 12 08:54:13 EST 2009
Donald Kerr wrote:
> Hi all,
> I've been working with OpenLayers for a short time and am a bit confused as
> to how to approach the task I have due to the fact that there appears to be
> so many ways of achieving my goal.
> Currently I get the data from an asp.net asmx web service and parse through
> the XML returned. This seems fine in terms of collecting the date but is
> very slow in Internet Explorer - no surprise. I want to add markers to a
> layer or layers with the ability to destroy each set of markers and reload
> them as the user drags the map. I am using the following code:
> for(var i=0; i<nodes.length; ++i) {
> var uniqueID =
> nodes[i].getElementsByTagName('UniqueID')[0].firstChild.nodeValue;
> var category
> =nodes[i].getElementsByTagName('Category')[0].firstChild.nodeValue;
> var description =
> nodes[i].getElementsByTagName('Description')[0].firstChild.nodeValue;
> var easting =
> nodes[i].getElementsByTagName('GridRef')[0].getElementsByTagName('Easting')[
> var northing =
> nodes[i].getElementsByTagName('GridRef')[0].getElementsByTagName('Northing')
> var lonLat = new OpenLayers.LonLat(easting, northing);
> var feature = new OpenLayers.Feature.Vector(
> new OpenLayers.Geometry.Point(lonLat.lon,
> lonLat.lat),
> uniqueID: uniqueID,
> category: category,
> description: description
> features.push(feature);
> myDataLayer.addFeatures(features);
> This all works fine and I am showing different icons based on a StyleMap
> that has the following code:
> var lookup = {
> 'Full': { externalGraphic: 'images/full.png' },
> 'Partial': { externalGraphic: 'images/partial.png' },
> 'Historic': { externalGraphic: 'images/historic.png' },
> 'MSF': { externalGraphic: 'images/msf.png', graphicWidth:
> 25, graphicHeight: 25 }
> vmdsDataStyleMap.addUniqueValueRules('default', 'category', lookup);
> I can detroy all features in the layer using the following code:
> myDataLayer.removeFeatures(vmdsDataLayer.features);
> I have a list of things that I need to do and I am not sure of the best way
> to achieve this is. In the first instance, I want to be able to destroy only
> those features that are tagged, for example, 'Full' under 'category'. So
> that I can toggle on/off the features that I want to view. Is adding these
> all to one layer the best way to achieve this or should I each category to a
> new vector layer? Indeed, is a vector layer the best way to achieve this?
> In addidion to the above, I need to do the following:
> 1. Add a label to each icon that I can toggle on and off using some external
> javascript.
That's not currently possible with OpenLayers, but you could display a
small popup instead.
> 2. Change the css of the above label to show it bigger on mouseover or, if
> the labels aren't toggled on, simply show the label onmouseover.
You could use a SelectFeature control for you vector layer with the
option hover:true and changing the style of your selected features. The
popup could appear as the feature gets selected.
http://openlayers.org/dev/examples/select-feature.html
http://openlayers.org/dev/examples/select-feature-openpopup.html
> 3. Redirect the browser to a different url using the onclick of the icon.
You could do that with a Handler.Feature with the option {click:
onFeatureClicked} and created your onFeatureClicked function that open a
different url.
> 4. I can already set the icon up to be draggable but I need to save new
> coordinates to a database onmouseup. I need to capture the icon's 'UniqueID'
> onmouseup to do that, I assume. How is this done.
> Is a vector layer suitable for what I am trying to do or is there a better
> an easier way to do the above?
A vector layer is suitable, but you need to have you data in some
database format, like PostGIS and to use a server application that
supports transactions like Insert/Update/Delete, like GeoServer or TinyOWS.
> Any help or advice would be very much appreciated.
> Many thanks.
> Regards,
> Donald
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Hope this helps,
Alexandre Dubé
Mapgears
www.mapgears.com
