[OpenLayers-Users] PropertyStyles not working in IE7
Andreas Hocevar
ahocevar at opengeo.org
Mon Jan 12 11:40:36 EST 2009
Peter.Sykora at ooe.gv.at wrote:
>> You will want to add a second argument to applyDefaults, e.g.
>> OpenLayers.Feature.Vector.style["default"]. See below.
> thanks for your hint, but I tried that as well, same error. I also
> tried:
> var gemSymbolizer = new
> OpenLayers.Util.applyDefaults(
> strokeColor: "black",
> strokeWidth: 1,
> strokeOpacity: 0.6,
> fillOpacity: 0.8
> var gemStyle = new OpenLayers.StyleMap(
> default: gemSymbolizer,
> select: { strokeColor:
> "yellow", strokeWidth: 3, strokeOpacity: 0.9 }
> Again, works fine in FF but not in IE7
Ok, now I see what's wrong: "default" is a keyword in IE, so you have to
use quotes in the hash definition, like this:
"default": gemSymbolizer,
"select": selectSymbolizer
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
