[OpenLayers-Users] Drag feature control slow in IE
João Duarte
joao.c.duarte at co.sapo.pt
Tue Jan 13 17:53:09 EST 2009
In versions 7 and 8 that happens to me (and André).
You don't see any difference in the example behavior (regarding to speed),
while dragging a feature?
Regards,
João Duarte
http://maps.sapo.pt
-----Mensagem original-----
De: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Em
nome de Zac Spitzer
Enviada: terça-feira, 13 de Janeiro de 2009 22:48
Para: Andre Pereira de Matos
Cc: users at openlayers.org
Assunto: Re: [OpenLayers-Users] Drag feature control slow in IE
which version of IE, the example is fine for me in IE7 ?
On Wed, Jan 14, 2009 at 4:56 AM, Andre Pereira de Matos
<andre.matos at co.sapo.pt> wrote:
> Yes, the same issue occurres when you used this example on IE.
> Is it a bug? Any plans/suggestions to fix it?
> Regards,
> André Matos
> http://maps.sapo.pt
> -----Original Message-----
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of Frédéric Junod
> Sent: terça-feira, 13 de Janeiro de 2009 15:03
> To: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Drag feature control slow in IE
> Hi,
> Do you have the same issue with
> http://openlayers.org/dev/examples/drag-feature.html ?
> Your code looks reasonable to me ...
> fredj
> Le Tue, 13 Jan 2009 14:43:46 +0000,
> Andre Pereira de Matos <andre.matos at co.sapo.pt> a écrit :
>> Hi list,
>> I have done an example with a draggable feature (with
DragFeatureControl). In
>> Firefox, Google Chrome works fine... But when I drag it on IE it is very
>> slow...
>> The code used is:
>> markersLayer = new OpenLayers.Layer.Vector("Markers",
projection:
>> new OpenLayers.Projection("EPSG:4326"), styleMap: new
OpenLayers.StyleMap({
externalGraphic:
>> "http://openlayers.org/dev/img/marker-gold.png", backgroundGraphic:
>> "http://openlayers.org/dev/examples/marker_shadow.png", graphicYOffset:
-20,
backgroundXOffset:
>> 0, backgroundYOffset: -17,
pointRadius:
>> 10 })
>> map.addLayer(markersLayer);
>> feature1 = new OpenLayers.Feature.Vector(new
>> OpenLayers.Geometry.Point(-1904105.3415234375, 4392319.753066596));
feature2
>> OpenLayers.Geometry.Point(-1504105.3415234375, 4392319.753066596));
>> markersLayer.addFeatures([feature1, feature2]);
>> var ccontrol = new
>> OpenLayers.Control.DragFeature(markersLayer); map.addControl(ccontrol);
>> ccontrol.activate();
>> Any suggestions? Is it a bug? Will it be fixed?
>> Regards,
>> André Matos
>> http://maps.sapo.pt
> Frédéric Junod
> Camptocamp SA
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
Users mailing list
