[OpenLayers-Users] Google and UK grid vector overlay
Thomas Wood grand.edgemaster at gmail.com
Wed Jan 14 09:58:24 EST 2009
I have an Ordnance Survey transformation class, for those that do not wish to
use proj4js.
It is available for download at
http://ge.pythonmoo.co.uk/maps/OpenLayers.Projection.OrdnanceSurvey.js
Please _do not_ hotlink to it.
goliah wrote:
> Hi Arnd.
> thank you for your response.
> No, i didn't include proj4js in my page.
> Now I've tried to include it in my html page (and include all the
> definitions), but it still does not work.
> Any other ideas?
> Thank you!
> Mauro
> 2009/1/13 Arnd Wippermann <arnd.wippermann at web.de>:
>> The code is correct.Have you included proj4js in your page?
>> Otherwise
>> Transform depends on the proj4js library.
>> If proj4js is not available, then this is just an empty stub.
>> Arnd Wippermannn
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> Im
>> Auftrag von Mauro Bianchi
>> Gesendet: Dienstag, 13. Januar 2009 11:51
>> An: users at openlayers.org
>> Betreff: [OpenLayers-Users] Google and UK grid vector overlay
>> Dear all,
>> I'm pretty new to OL and I want to do the following
>> 1) have a google layer as a base layer
>> 2) overlay a vector layer and add points programmatically. Points
>> coordinates are given in the UK national grid system (OSGB , which should
>> be
>> EPSG:27700)
>> I could convert points coordinates externally, but I'd prefer to do it
>> directly into OpenLayers, if possibile.
>> I tried different methods but cannot get it working.
>> Any help would be really appreciated!
>> Thank you
>> Mauro
>> My code is the following
>> var map;
>> var options = {
>>        projection: new OpenLayers.Projection("EPSG:900913"),
>>        displayProjection: new OpenLayers.Projection("EPSG:4326"),
>>        units: "m",
>>        numZoomLevels: 18,
>>        maxResolution: 156543.0339,
>>        maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
>> 20037508, 20037508.34)
>> map = new OpenLayers.Map('map', options);
>> //google maps layer, physical
>> var gphy = new OpenLayers.Layer.Google(
>>        "Google Physical",
>>        {type: G_PHYSICAL_MAP, numZoomLevels: 20,
>> 'sphericalMercator':true}
>> map.addLayers([gphy]);
>> //a vector layer where i want to add points programmatically var
>> vectorLayer
>> = new OpenLayers.Layer.Vector("My Geometry");
>> //this is a point that i want to add in UK grid coordinates var point =
>> new
>> OpenLayers.Geometry.Point(519000, 165222).transform( new
>> OpenLayers.Projection("EPSG:27700"), map.projection); var pointFeature =
>> new
>> OpenLayers.Feature.Vector(point);
>> vectorLayer.addFeatures([pointFeature]);
>> map.addLayer(vectorLayer);
>> //controls and centering
>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>> map.setCenter(new
>> OpenLayers.LonLat(-0.126343,51.539502).transform(map.displayProjection,
>> map.projection), 10);
>> Mauro Bianchi
>> bianchimro at gmail.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Mauro Bianchi
> Users mailing list
View this message in context: http://n2.nabble.com/Google-and-UK-grid-vector-overlay-tp2150605p2157235.html
