[OpenLayers-Users] Google and UK grid vector overlay
Mauro Bianchi bianchimro at gmail.com
Wed Jan 14 13:58:02 EST 2009
Hi Thomas,
with your transformation class everything works perfect!
So I think I stay this implementation, but I still can't understand
why my proj4s version is not working.
Thanks a lot
Mauro
2009/1/14 Thomas Wood <grand.edgemaster at gmail.com>:
> I have an Ordnance Survey transformation class, for those that do not wish to
> use proj4js.
> It is available for download at
> http://ge.pythonmoo.co.uk/maps/OpenLayers.Projection.OrdnanceSurvey.js
> Please _do not_ hotlink to it.
> goliah wrote:
>> Hi Arnd.
>> thank you for your response.
>> No, i didn't include proj4js in my page.
>> Now I've tried to include it in my html page (and include all the
>> definitions), but it still does not work.
>> Any other ideas?
>> Thank you!
>> Mauro
>> 2009/1/13 Arnd Wippermann <arnd.wippermann at web.de>:
>>> The code is correct.Have you included proj4js in your page?
>>> Otherwise
>>> Transform depends on the proj4js library.
>>> If proj4js is not available, then this is just an empty stub.
>>> Arnd Wippermannn
>>> -----Ursprüngliche Nachricht-----
>>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>>> Im
>>> Auftrag von Mauro Bianchi
>>> Gesendet: Dienstag, 13. Januar 2009 11:51
>>> An: users at openlayers.org
>>> Betreff: [OpenLayers-Users] Google and UK grid vector overlay
>>> Dear all,
>>> I'm pretty new to OL and I want to do the following
>>> 1) have a google layer as a base layer
>>> 2) overlay a vector layer and add points programmatically. Points
>>> coordinates are given in the UK national grid system (OSGB , which should
>>> be
>>> EPSG:27700)
>>> I could convert points coordinates externally, but I'd prefer to do it
>>> directly into OpenLayers, if possibile.
>>> I tried different methods but cannot get it working.
>>> Any help would be really appreciated!
>>> Thank you
>>> Mauro
>>> My code is the following
>>> var map;
>>> var options = {
>>>        projection: new OpenLayers.Projection("EPSG:900913"),
>>>        displayProjection: new OpenLayers.Projection("EPSG:4326"),
>>>        units: "m",
>>>        numZoomLevels: 18,
>>>        maxResolution: 156543.0339,
>>>        maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
>>> 20037508, 20037508.34)
>>> map = new OpenLayers.Map('map', options);
>>> //google maps layer, physical
>>> var gphy = new OpenLayers.Layer.Google(
>>>        "Google Physical",
>>>        {type: G_PHYSICAL_MAP, numZoomLevels: 20,
>>> 'sphericalMercator':true}
>>> map.addLayers([gphy]);
>>> //a vector layer where i want to add points programmatically var
>>> vectorLayer
>>> = new OpenLayers.Layer.Vector("My Geometry");
>>> //this is a point that i want to add in UK grid coordinates var point =
>>> new
>>> OpenLayers.Geometry.Point(519000, 165222).transform( new
>>> OpenLayers.Projection("EPSG:27700"), map.projection); var pointFeature =
>>> new
>>> OpenLayers.Feature.Vector(point);
>>> vectorLayer.addFeatures([pointFeature]);
>>> map.addLayer(vectorLayer);
>>> //controls and centering
>>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>>> map.setCenter(new
>>> OpenLayers.LonLat(-0.126343,51.539502).transform(map.displayProjection,
>>> map.projection), 10);
>>> Mauro Bianchi
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Mauro Bianchi
>> Users mailing list
> View this message in context: http://n2.nabble.com/Google-and-UK-grid-vector-overlay-tp2150605p2157235.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
Mauro Bianchi
