[OpenLayers-Users] Disable Zoom wheel
Andre Pereira de Matos andre.matos at co.sapo.pt
Fri Jan 16 12:11:23 EST 2009
Which controls do you have on your map?
How are you initializing the map?
That could be happening because there are some controls that are adding a new Navigation control to your map...
If is it the only way you have to solve that problem is:
controls = map.getControlsByClass('OpenLayers.Control.Navigation');
for(var I = 0; i<controls.length; ++i)
controls.disableZoomWheel();
Regards,
André Matos
http://maps.sapo.pt
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of Alexandre Ardhuin
Sent: sexta-feira, 16 de Janeiro de 2009 16:53
To: darrepac
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Disable Zoom wheel
By changing movemap in navigationControl, this should be OK.
Alexandre
2009/1/16 darrepac <pascal.darre at laposte.net<mailto:pascal.darre at laposte.net>>
Hi
Thanks for your help
I did this:
     var movemap = new OpenLayers.Control.Navigation({'zoomWheelEnabled':
false});
     map.addControl(movemap);
     movemap.activate();
     movemap.disableZoomWheel();
and the wheel still work.... :(
Alexandre Ardhuin wrote:
> Hi you can use :
> navigationControl.disableZoomWheel();
> navigationControl.enableZoomWheel();
> Alexandre.
>> Hi,
>> I browse the user list to find how to disable the mouse wheel in the map.
>> I think I find the way to do it but it doesn't work, here is my code:
>> false});
>>      movemap.activate();
>> thanks for the help
>> View this message in context:
>> http://n2.nabble.com/Disable-Zoom-wheel-tp2169123p2169123.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org<mailto:Users at openlayers.org>
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://n2.nabble.com/Disable-Zoom-wheel-tp2169123p2169239.html
Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090116/6fb42b8d/attachment.html
