[OpenLayers-Users] DrawFeature control not working properly
Jatin Ambasana jatin.a at iworktech.com
Tue Jan 20 02:32:10 EST 2009
Hi Eric,
> Does the test also fail with trunk? (I can't check right now)
Frankly speaking I don't understand your question..... I mean I don't know
where to test the trunk?
I just have OpenLayers-2.7 folder that I downloaded from OpenLayers website.
I went to http://trac.openlayers.org/browser/
and got a view of the revisions and other things.....
OpenLayers has nice support.... Thanks to you people...
But I don't see anything over there to test the stuff or run the page
run-tests.html....
Will I have to download the whole trunk part that is revised and then test
it out?
I mean I don't have much idea about the trunk and other things.... Can you
please guide me on that so that I can make its proper use and also become
helpful to others....
thank you.....
Eric Lemoine wrote:
> Hi Jatin
> Eric
> 2009/1/20, Jatin Ambasana <jatin.a at iworktech.com>:
>> Hello Eric,
>>>What OpenLayers version do you use?
>> I use OpenLayers-2.7 latest version.
>>>Changeset 8616 (<http://trac.openlayers.org/changeset/8616>) should
>>>fix it, give trunk a try.
>> Yes Thank you very much Eric..... it has solved my problem....=)
>> I am able to draw the polygon on single click and also add it in the
>> layer.....
>> Here is the code added in zip file that I have done to just draw a circle
>> of
>> specific size on just one click and also it provides a functionality that
>> user can draw only one circle at a time..... it could be useful for
>> someone
>> else also.....
>> But Eric,
>> There is one problem that I think I need to inform you about...
>> I updated both the files
>> from http://trac.openlayers.org/changeset/8616
>> i.e.
>> 1) trunk/openlayers/lib/OpenLayers/Handler/RegularPolygon.js (modified)
>> (1
>> diff)
>> 2) trunk/openlayers/tests/Handler/RegularPolygon.html (modified) (1 diff)
>> Now when I tested the RegularPolygon.html in
>> http://localhost/OpenLayers-2.7/tests/run-tests.html
>> It gives one error while testing.... I am pasting the output in italics
>> below:
>> Handler/RegularPolygon.html: fail 1 ok 6 (detailed: fail 0 ok 25)
>> test_Handler_RegularPolygon_constructor ok 3
>> ok constructor calls parent with the correct control
>> ok constructor calls parent with the correct callbacks
>> ok regular polygon constructor calls parent with the correct options
>> test_Handler_RegularPolygon_activation ok 3
>> ok activate returns false if the handler was already active
>> ok activate returns true if the handler was not already active
>> ok deactivate returns true if the handler was active already
>> test_Handler_RegularPolygon_deactivation ok 1
>> ok deactivate doesn't throw an error if layer was previously destroyed
>> test_Handler_RegularPolygon_four_corners ok 7
>> ok correct bounds after move
>> ok geometry has 5 components
>> ok geometry is a polygon
>> ok feature radius as set on handler
>> ok correct bounds after move with a fixed radius
>> ok bounds with manual radius setting
>> ok bounds with manual radius setting and mousemove
>> test_Handler_RegularPolygon_circle ok 7
>> ok geometry has correct numbre of components
>> ok correct bounds after move with fixed radius
>> test_Handler_RegularPolygon_irregular ok 4
>> ok correct right
>> ok correct bottom
>> ok correct left
>> ok correct top
>> test_callbacks planned 1 assertions but got 0; fail 0 ok 0
>> exception: : object: 'bottom' is null or not an object
>> Eric Lemoine wrote:
>>> On Mon, Jan 19, 2009 at 1:52 PM, Jatin Ambasana <jatin.a at iworktech.com>
>>> wrote:
>>>>  http://mail.google.com/mail/#label/openlayers/11eeef3d8dc95c53
>>>> Hello everyone,
>>>> I have added DrawFeature control to my map.
>>>> Whenever it is activated it will always draw a polygon of sides 40 i.e.
>>>> an
>>>> approx circle.
>>>> This is its code:
>>>>             polyOptions = {sides: 40, radius: rad, angle: 0};
>>>>             polygonControl = new
>>>> OpenLayers.Control.DrawFeature(polygonLayer,
>>>> OpenLayers.Handler.RegularPolygon,
>>>>                                             {handlerOptions:
>>>> polyOptions,
>>>> featureAdded:circleAdded});
>>>>             map.addControl(polygonControl);
>>>> Now the problem is that the circleAdded function is not called when a
>>>> circle
>>>> is drawn on map.
>>> Regards,
>>> Eric
>>>  http://n2.nabble.com/file/n2185143/polygons.zip polygons.zip
>> View this message in context:
>> http://n2.nabble.com/DrawFeature-control-not-working-properly-tp2181102p2185143.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://n2.nabble.com/DrawFeature-control-not-working-properly-tp2181102p2185328.html
