[OpenLayers-Users] Problem whit "Same-origin policy"
Pablo Díaz
inspdr00 at gmail.com
Tue Jan 20 03:07:50 EST 2009
Thank you again!!
I understood your solution, I'm going to search by the net.
Thank you so much!!!!
El lun, 19-01-2009 a las 14:58 -0500, Amos Hayes escribió:
> Hi Pablo.
> If you are running tomcat on port 80, then deploying GeoServer as a
> WAR file under tomcat should allow you to access it on port 80 as well
> and might be the easiest solution for you. See the geoserver docs for
> information on deploying as a war file.
> If you need to run tomcat and geoserver separately, or you are running
> both on ports that are different than the one serving the HTML page,
> and you want to serve a page from one and get (non-image) content from
> another, then you'll need to reverse proxy. See the Apache proxy
> documentation.
> Either way, the URLs you use for loading vectors in openlayers need to
> refer to the same host and port as the host/port combination the page
> was loaded from.
> I'm sorry I can't be much more help. You're probably in for a bit of
> googling and doc reading to sort out a solution for your environment.
> Amos Hayes
> Geomatics and Cartographic Research Centre
> Carleton University
> ahayes at gcrc.carleton.ca
> +1.613.520.2600x8179
> On 19-Jan-09, at 12:18 PM, Pablo Díaz wrote:
> > Thanks so much!!
> > But, how do I do that?
> > I've tomcat rus on port 80, geoserver runs on port 8080 and I runs
> > most
> > of GETs with OpenLayers (I draw polygons, I put the result into a
> > textarea, I select polygons) but I can't use GetFeatureInfo with
> > diferent port.
> > Thank you again!!.
> > El lun, 19-01-2009 a las 12:08 -0500, Amos Hayes escribió:
> >> It's a browser security feature. You'll need to set up a reverse
> >> proxy. If you run Apache on port 80 and use its reverse proxy
> >> features, you can put your various services under a port 80 path.
> >> Amos Hayes
> >> Carleton University
> >> On 19-Jan-09, at 11:56 AM, Pablo Díaz wrote:
> >>> Hello list,
> >>> Well, excuse my English.
> >>> I've an application with OpenLayers, Tomcat an Geoserver.
> >>> When I try to connect my application in tomcat with vector layers in
> >>> Geoserver, I've no problem if geoserver runs in port 80 (the same as
> >>> tomcat), but when I try to connect when geoserver runs in port
> >>> 8080 I
> >>> get the next exception by firebug:
> >>> Access to restricted URI denied" code: "1012
> >>> http://localhost/VisorOL/javascript/OpenLayers-2.7/OpenLayers.js
> >>> Line 513
> >>> Seaching, I found that this error means that I broke the "Same-
> >>> origin
> >>> policy", but I don't know how arrange this problem.
> >>> I need geoserver runs in port 8080 not in port 80.
> >>> Some idea?.
> >>> _______________________________________________
> >>> Users mailing list
> >>> Users at openlayers.org
> >>> http://openlayers.org/mailman/listinfo/users
