[OpenLayers-Users] Projection problem
David Martinez Morata
damarmo at gmail.com
Tue Jan 20 14:27:55 EST 2009
I try this...But don't works
What ever i continue tomoroww
Thanks
2009/1/20 Brent Pedersen <bpederse at gmail.com>
> seems you're requesting the layer in 900913, but that's not listed in
> your wms_srs list. what happens if you add 900913 to the list?
> On Tue, Jan 20, 2009 at 8:30 AM, David Martinez Morata
> <damarmo at gmail.com> wrote:
> > I try this but doesn't work.
> > Thnks
> > 2009/1/20 Christopher Schmidt <crschmidt at metacarta.com>
> >> On Tue, Jan 20, 2009 at 05:15:10PM +0100, David Martinez Morata wrote:
> >> > All My layers are
> >> > "PROJECTION
> >> > "init=epsg:27572"
> >> > END"
> >> > definition in the mapfile
> >> > And the MAP object have the same definition.
> >> > It's for this I put the value in var georoute definition
> >> > "reproject": true,
> >> > in the var options for Openlayers map I define this
> >> > var options = {numZoomLevels: 30,
> >> > projection: new OpenLayers.Projection("EPSG:900913"),
> >> > displayProjection: new OpenLayers.Projection("EPSG:4326"),
> >> > units: "m",
> >> > maxResolution: 156543.0339,
> >> > maxExtent: new OpenLayers.Bounds(-20037508, -20037508, 20037508,
> >> > 20037508.34)};
> >> You're requesting the map tiles to be in EPSG:900913. EPSG:900913 is not
> >> an option in your wms_srs metadata, so the MapServer can't serve tiles
> >> inthat projection. If you want to use that projection, add it to
> >> wms_srs.
> >> Regards,
> >> Christopher Schmidt
> >> MetaCarta
> > Martinez Morata David
> > Thinking GIS
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
Thinking GIS
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090120/14d713cc/attachment.html
