[OpenLayers-Users] Projection problem
David Martinez Morata damarmo at gmail.com
Wed Jan 21 05:43:44 EST 2009
Ok
I test change the vector layer for a epsg:27572 code (my layers are in this
SRS) ands i have the same problem
I think I couldn't make two reprojections of my layers in the server.(?)
Thnks for any other sugestion
2009/1/20 Arnd Wippermann <arnd.wippermann at web.de>
>  Hi,
> perhaps the projection EPSG:900913 is not defined in your espg-file in the
> proj-directory for Mapserver
> Arnd Wippermann
> *Von:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> *Im Auftrag von *David Martinez Morata
> *Gesendet:* Dienstag, 20. Januar 2009 20:28
> *An:* Brent Pedersen
> *Cc:* users
> *Betreff:* Re: [OpenLayers-Users] Projection problem
> I try this... But don't works
> What ever i continue tomoroww
> Thanks
> 2009/1/20 Brent Pedersen <bpederse at gmail.com>
>> seems you're requesting the layer in 900913, but that's not listed in
>> your wms_srs list. what happens if you add 900913 to the list?
>> On Tue, Jan 20, 2009 at 8:30 AM, David Martinez Morata
>> <damarmo at gmail.com> wrote:
>> > I try this but doesn't work.
>> > Thnks
>> > 2009/1/20 Christopher Schmidt <crschmidt at metacarta.com>
>> >> On Tue, Jan 20, 2009 at 05:15:10PM +0100, David Martinez Morata wrote:
>> >> > All My layers are
>> >> > "PROJECTION
>> >> >           "init=epsg:27572"
>> >> >   END"
>> >> > definition in the mapfile
>> >> > And the MAP object have the same definition.
>> >> > It's for this I put the  value in var georoute  definition
>> >> > "reproject": true,
>> >> > in the var options for  Openlayers map I define this
>> >> > var options = {numZoomLevels: 30,
>> >> > projection: new OpenLayers.Projection("EPSG:900913"),
>> >> > displayProjection: new OpenLayers.Projection("EPSG:4326"),
>> >> > units: "m",
>> >> > maxResolution: 156543.0339,
>> >> > maxExtent: new OpenLayers.Bounds(-20037508, -20037508, 20037508,
>> >> > 20037508.34)};
>> >> You're requesting the map tiles to be in EPSG:900913. EPSG:900913 is
>> not
>> >> an option in your wms_srs metadata, so the MapServer can't serve tiles
>> >> inthat projection. If you want to use that projection, add it to
>> >> wms_srs.
>> >> Regards,
>> >> Christopher Schmidt
>> >> MetaCarta
>> > Martinez Morata David
>> > Thinking GIS
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
> Thinking GIS
Thinking GIS
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090121/8c503558/attachment.html
