[OpenLayers-Users] FEatures orders
Andreas Hocevar ahocevar at opengeo.org
Thu Jan 22 04:04:53 EST 2009
darrepac wrote:
> darrepac wrote:
>>> You decide. Not the absolute z-index, only the order is relevant
>>> (greater than / less than comparison). This z-index also has nothing
>>> to do with the CSS z-index.
>> Ok but I just want to know example value to not put stupid value which
>> will make the features below the map for example...So for example if you
>> tell me that features z-index value should be around 500, I will play
>> around this number...but may-be it is 20, 2000....
>> thanks
> Do you mean we can stay at the relative level and not putting absolute value
> may-be....if yes, how?
You do not use CSS z-index here. All you have to do is set the
graphicZIndex property of your symbolizer, as the ordering.html example
shows:
var layer = new OpenLayers.Layer.Vector(
    "Y-Order",
        styleMap: new OpenLayers.StyleMap({
            externalGraphic: "../img/marker-gold.png",
            pointRadius: 10,
            graphicZIndex: GOLD_Z_INDEX
        isBaseLayer: true,
        rendererOptions: {yOrdering: true}
You will not want the yOrdering renderer option, but instead:
        rendererOptions: {zIndexing: true}
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
