[OpenLayers-Users] FEatures orders
Andreas Hocevar ahocevar at opengeo.org
Thu Jan 22 06:28:43 EST 2009
darrepac wrote:
> So my question was, which value I put for GOLD_Z_INDEX ?
Seems I'm unable to make myself clear. Last try: it really does not
matter. If you have let's say 100 features, sorted descending by size,
you give the first one a graphicZIndex of 1, and 100 for the last one.
Andreas.
> thanks
> Andreas Hocevar-2 wrote:
>> darrepac wrote:
>>> darrepac wrote:
>>>>> You decide. Not the absolute z-index, only the order is relevant
>>>>> (greater than / less than comparison). This z-index also has nothing
>>>>> to do with the CSS z-index.
>>>> Ok but I just want to know example value to not put stupid value which
>>>> will make the features below the map for example...So for example if you
>>>> tell me that features z-index value should be around 500, I will play
>>>> around this number...but may-be it is 20, 2000....
>>>> thanks
>>> Do you mean we can stay at the relative level and not putting absolute
>>> value
>>> may-be....if yes, how?
>> You do not use CSS z-index here. All you have to do is set the
>> graphicZIndex property of your symbolizer, as the ordering.html example
>> shows:
>> var layer = new OpenLayers.Layer.Vector(
>>     "Y-Order",
>>         styleMap: new OpenLayers.StyleMap({
>>             externalGraphic: "../img/marker-gold.png",
>>             pointRadius: 10,
>>             graphicZIndex: GOLD_Z_INDEX
>>         isBaseLayer: true,
>>         rendererOptions: {yOrdering: true}
>> You will not want the yOrdering renderer option, but instead:
>>         rendererOptions: {zIndexing: true}
>> Regards,
>> Andreas.
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
