[OpenLayers-Users] GetFeatureInfo not working
nm3456 at gmail.com nm3456 at gmail.com
Mon Jan 26 15:47:55 EST 2009
Hi everyone,
Being newbies with Geoserver-Openlayers, we set up an application, on a
machine with Windows Server 2003-IIS.
Everything works fine apart from the GetFeatureInfo calls.
>From firebug, we located the following request, when we click on the map,
which works fine, when we use it at the browser's address bar:
http://84.205.237.73:443/geoserver/wms?REQUEST=GetFeatureInfo
<http://84.205.237.73:443/geoserver/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=ap
plication%2Fvnd.ogc.se_xml&BBOX=2767167.493482%2C4505675.646451%2C2822912.47
0114%2C4540167.850742&X=469&Y=327&INFO_FORMAT=text%2Fhtml&QUERY_LAYERS=Tinos
%3Adimoi&FEATURE_COUNT=50&Layers=Tinos%3Adimoi&Styles=&Srs=EPSG%3A900913&WID
TH=800&HEIGHT=495&format=image%2Fpng>
&EXCEPTIONS=application%2Fvnd.ogc.se_xml&BBOX=2767167.493482%2C4505675.64645
1%2C2822912.470114%2C4540167.850742&X=469&Y=327&INFO_FORMAT=text%2Fhtml&QUER
Y_LAYERS=Tinos%3Adimoi&FEATURE_COUNT=50&Layers=Tinos%3Adimoi&Styles=&Srs=EPS
G%3A900913&WIDTH=800&HEIGHT=495&format=image%2Fpng
>From the above we concluded that there is a browser security problem.
So far, we followed:
1)       http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
2)
http://n2.nabble.com/Solution-to-proxy-for-WFS-request-on-IIS-td1830924.html
#a20353666
3)       http://openlayers.org/dev/examples/getfeatureinfo.html
4)
http://n2.nabble.com/GetFeatureInfo-requests-never-get-answers-td1824945.htm
l#a11586620
But now, instead of getting an endless "Loading... please wait...",
we get an "HTTP Error 404 - File or directory not found.", when we click on
the map.
For our demo map go to: http://84.205.237.73/default/demomap.aspx
I apologize for the Greek language used, but you should be able to browse
the code :))
I hope that someone has a suggestion.
 Nikos
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090126/63270c16/attachment.html
