[OpenLayers-Users] Ancored Popup Autosize troubles
Sebastian Benthall
seb at opengeo.org
Wed Jan 28 11:03:30 EST 2009
Ok. Looking at your application now, but I don't understand what it is
that's giving you a hard time.
What behavior do you want/expect that you aren't getting?
On Wed, Jan 28, 2009 at 10:12 AM, smithfield <willsmithfield at gmail.com>wrote:
> Unfortunately, that didn't really answer the question. Could you be more
> specific?
> Thanks.
> 小粟 wrote:
> > I just checked the content size and set the popup size dynamicly.
> > Regards,
> > suen
> > ----- Original Message -----
> > From: "smithfield" <willsmithfield at gmail.com>
> > To: <users at openlayers.org>
> > Sent: Tuesday, January 27, 2009 9:40 AM
> > Subject: [OpenLayers-Users] Ancored Popup Autosize troubles
> >> Hello list. I have my map just about where I need it but the anchored
> >> popups
> >> are giving me a hard time. I have tried to include the autosize command
> >> with little luck. Any thoughts?
> >> Regards-WS
> >> <html xmlns="http://www.w3.org/1999/xhtml">
> >> <head>
> >> <title>World Map</title>
> >> <style type="text/css">
> >> #map {
> >> width: 1000px;
> >> height: 600px;
> >> border: 1px solid black;
> >> </style>
> >> <script
> >> src='
> http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ
> '></script>
> >> <script type="text/javascript"
> >> src="http://openlayers.org/api/OpenLayers.js"></script>
> >> <script type="text/javascript" src="data/world_borders.js"></script>
> >> <script type="text/javascript">
> >> var map;
> >> var popup;
> >> function init(){
> >> var options = {
> >> projection: new OpenLayers.Projection("EPSG:900913"),
> >> displayProjection: new
> OpenLayers.Projection("EPSG:4326"),
> >> units: "m",
> >> maxResolution: 156543.0339,
> >> numZoomLevels: 10,
> >> maxExtent: new OpenLayers.Bounds(-20037508.34,
> >> -20037508.34,
> >> 20037508.34,
> 20037508.34)
> >> map = new OpenLayers.Map('map',options);
> >> var gmap = new OpenLayers.Layer.Google("Google Streets",
> >> 'sphericalMercator': true
> >> map.addLayer(gmap);
> >> var colors =
> >> ["#7d0000","#be0b00","#e65100","#ff9700","#fcc900"];
> >> var ranges = [15,30,45,60,75];
> >> var context = {
> >> getColor: function(feature) {
> >> for (var i = 0; i < ranges.length; i++){
> >> if (feature.attributes.Act_T <= ranges[i]){
> >> return colors[i];
> >> //return "#99000d";
> >> var template = {
> >> fillColor: "${getColor}", // using
> >> context.getColor(feature)
> >> fillOpacity: ".75",
> >> strokeColor:"black",
> >> strokeWidth:1
> >> var style = new OpenLayers.Style(template, {context:
> >> context});
> >> var styleMap = new OpenLayers.StyleMap({'default': style,
> >> select: {fillColor: "333333"}, hover: {fillColor: "333333"}});
> >> var geoJSON = new OpenLayers.Format.GeoJSON();
> >> var world_borders = new OpenLayers.Layer.Vector("Open Source
> >> Activity",{styleMap:styleMap, isBaseLayer: false,
> >> projection: new OpenLayers.Projection("EPSG:4326"),
> >> attribution: " www.zzzzz.com zzzz "});
> >> world_borders.addFeatures(geoJSON.read(features));
> >> map.addLayer(world_borders);
> >> var select = new
> OpenLayers.Control.SelectFeature(world_borders,{hover:true,clickFeature:createPopup,onUnselect:unSelect});
> >> map.addControl(select);
> >> select.activate();
> >> map.addControl(new OpenLayers.Control.MousePosition());
> >> var center = new OpenLayers.LonLat(0,30);
> >> center.transform(map.displayProjection,map.getProjectionObject());
> >> map.setCenter(center, 2);
> >> function createPopup(feature){
> >> if (popup != null) {
> >> map.removePopup(popup);
> >> popup.destroy();
> >> popup = null;
> >> feature.lonlat =
> >> feature.geometry.getBounds().getCenterLonLat();
> >> if (popup == null) {
> >> popup = new OpenLayers.Popup.Anchored ("popup",
> >> feature.lonlat, new OpenLayers.Size(200,200),
> >> null, null, null,
> >> function () {
> >> map.removePopup( popup ); popup.destroy();
> >> popup = null;
> >> var content = "<div>"+ feature.attributes.CNTRY_NAME +
> >> "</div><br>" +
> >> "<div><table>" +
> >> "<tr><th align='right'>Overall Rank:</th><td> " +
> >> feature.attributes.Act_T + "</td></tr>" +
> >> "<tr><th align='right'>Government Rank:</th><td> " +
> >> feature.attributes.Act_G + "</td></tr>" +
> >> "<tr><th align='right'>Industry Rank:</th><td>" +
> >> feature.attributes.Act_I + "</td></tr>" +
> >> "<tr><th align='right'>Community Rank:</th><td> " +
> >> feature.attributes.Act_C + " </td></tr>" +
> >> "</table></div>";
> >> popup.setContentHTML(content);
> >> popup.setBackgroundColor("white");
> >> popup.setOpacity(1);
> >> popup.events.register('mousemove', popup, function (e)
> >> {try{e.stopPropagation();}catch(e){}});
> >> map.addPopup(popup);
> >> } else {
> >> popup.destroy();
> >> popup = null;
> >> function unSelect(){
> >> popup.destroy();
> >> popup = null;
> >> </script>
> >> </head>
> >> <body onload="init()">
> >> <center>
> >> <div id="map"></div>
> >> </center>
> >> </body>
> >> </html>
> >> any thoughts on disabling the scroll wheel would be great too!
> >> Thanks
> >> View this message in context:
> http://n2.nabble.com/Ancored-Popup-Autosize-troubles-tp2221855p2221855.html
> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > Users mailing list
> http://n2.nabble.com/Ancored-Popup-Autosize-troubles-tp2221855p2232720.html
> Users mailing list
Sebastian Benthall
OpenGeo - http://opengeo.org
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090128/c4fc2f9c/attachment.html
