[OpenLayers-Users] how to deactivate editingtoolbar after featureadded
Alexandre Dube adube at mapgears.com
Wed Jan 28 12:02:43 EST 2009
Take a look at this example (1). Zoom in and out the map. You will see
that the buttons completely disappear. That could be an other option to
your issue.
(1) http://dev4.mapgears.com/bdga/bdgaWFS-T.html
Regards,
Alexandre
G. Allegri wrote:
> Sorry, I've sent too fast the solution. It works, but how can I
> overload the onClick event on the control to alert the user with "a
> feature has been already added"?
> In this case I don't have to stop observing the click but I need to
> handle it in a custom way...
> 2009/1/28 G. Allegri <giohappy at gmail.com>:
>> Solved (somehow...):
>>       function locAdded(feature){
>>                for(i=0;i<3;i++){
>>                        panel.controls[i+1].deactivate();
>>                        OpenLayers.Event.stopObservingElement(panel.controls[i+1].panel_div);
>> giovanni
>>> Hello list,
>>> I'm using the editingtoolbar control panel. I need to disable it after
>>> any feature has been added (point, line or polygon), and reactivate it
>>> if the feature gets deleted.
>>> I've seen that calling:
>>>                panel.controls[1].deactivate();
>>>                panel.controls[2].deactivate();
>>>                panel.controls[3].deactivate();
>>> deactivate the controls unitl the user click on the panel again...
>>> this is not what I need. In fact the panel control has an onClick
>>> handler that activate the control on which the onClick event has
>>> happened (line 212 in Panel.js).
>>> I've tried deactivating directly the panel, but the panel gets deleted.
>>> I need the panel to remain visible but "unclickable", until the unique
>>> feature has been deleted from the layer.
>>> I've tried to overload the onClick panel's method, but I couldn't get
>>> it to work...
>>> Thanks for any hint.
>>> giovanni
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
