[OpenLayers-Users] how to deactivate editingtoolbar after featureadded
G. Allegri giohappy at gmail.com
Wed Jan 28 12:56:59 EST 2009
My last guess has been:
var panel = new OpenLayers.Control.EditingToolbar(vettoriale);
OpenLayers.Util.extend(panel,{
		onClick: function (ctrl, evt) {
        	alert('ohoh');
but still the original behaviour happens...
2009/1/28 G. Allegri <giohappy at gmail.com>:
> Thansk Alexandre for the reply. This is not exatcly what I need to achieve.
> A first step is:
>    OpenLayers.Event.stopObservingElement(panel.controls[i+1].panel_div);
> but the true behaviour I want is something like this:
>    panel.onClick = function fn(c,e){alert('only one feature admitted');}
> but this way to overload the panel's onClick method doesn't work....
> 2009/1/28 Alexandre Dube <adube at mapgears.com>:
>> Hi,
>> Take a look at this example (1). Zoom in and out the map. You will see that
>> the buttons completely disappear. That could be an other option to your
>> issue.
>> (1) http://dev4.mapgears.com/bdga/bdgaWFS-T.html
>> Regards,
>> Alexandre
>> G. Allegri wrote:
>>> Sorry, I've sent too fast the solution. It works, but how can I
>>> overload the onClick event on the control to alert the user with "a
>>> feature has been already added"?
>>> In this case I don't have to stop observing the click but I need to
>>> handle it in a custom way...
>>>> Solved (somehow...):
>>>>      function locAdded(feature){
>>>>               for(i=0;i<3;i++){
>>>>                       panel.controls[i+1].deactivate();
>>>> giovanni
>>>>> Hello list,
>>>>> I'm using the editingtoolbar control panel. I need to disable it after
>>>>> any feature has been added (point, line or polygon), and reactivate it
>>>>> if the feature gets deleted.
>>>>> I've seen that calling:
>>>>>               panel.controls[1].deactivate();
>>>>>               panel.controls[2].deactivate();
>>>>>               panel.controls[3].deactivate();
>>>>> deactivate the controls unitl the user click on the panel again...
>>>>> this is not what I need. In fact the panel control has an onClick
>>>>> handler that activate the control on which the onClick event has
>>>>> happened (line 212 in Panel.js).
>>>>> I've tried deactivating directly the panel, but the panel gets deleted.
>>>>> I need the panel to remain visible but "unclickable", until the unique
>>>>> feature has been deleted from the layer.
>>>>> I've tried to overload the onClick panel's method, but I couldn't get
>>>>> it to work...
>>>>> Thanks for any hint.
>>>>> giovanni
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
