[OpenLayers-Users] Dragable markers
Andreas Hocevar ahocevar at opengeo.org
Mon Jul 6 07:27:23 EDT 2009
See http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Control/DragFeature-js.html#OpenLayers.Control.DragFeature.OpenLayers.Control.DragFeature
You need to configure the DragFeature control with the layer that
contains the features you want to drag.
Regards,
Andreas.
On Mon, Jul 6, 2009 at 12:15 PM, Admin
TrouveTonGull.info<contact at trouvetongull.info> wrote:
> Andreas Hocevar a écrit :
>> Hard to tell without seeing your code.
> oups sorry, my map: http://www.trouvetongull.info/carte/
>> But I would gess you are using
>> an OpenLayers.Layer.Markers or OpenLayers.Layer.GeoRSS. The
>> DragFeature control only works with vector layers (Layer.Vector,
>> Layer.GML, Layer.WFS). To see how to set this up, have a look at the
>> http://www.openlayers.org/dev/examples/behavior-fixed-http-gml.html
>> example. If you use GeoRSS and not GML, you will want to replace the
>> format (new OpenLayers.Format.GML()) with a GeoRSS format (new
>> OpenLayers.Format.GeoRSS).
> I use Georss markers on GML layers.
>> Regards,
>> Andreas.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
