[OpenLayers-Users] REPEAT QUESTION - How do I prevent my map from zooming out too far?
Andreas Hocevar ahocevar at opengeo.org
Mon Jul 20 16:36:57 EDT 2009
jim.meyer at concept-solutions.com wrote:
> Hi Andreas,
>    Thanks for your response.  Do these options need to be set for the base
> layer or for the map?  Also, do you have an example of the values that would
> confine my map to just one view of the world?
You can set them on the base layer or on the map.
Assuming that you use Spherical Mercator, have a look at
http://localhost/openlayers/examples/spherical-mercator.html for
possible values.
Regards,
Andreas.
> Again... thanks for your assistance,
> Jim
> James B. Meyer
> Java Programmer
> Concept Solutions, Inc.
> (703) 472-7838
> 11600 Sunrise Valley Drive
> Suite 300
> Reston, VA 20191
> -----Original Message-----
> From: andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] On Behalf
> Of Andreas Hocevar
> Sent: Monday, July 20, 2009 3:22 PM
> To: jim.meyer at concept-solutions.com
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] REPEAT QUESTION - How do I prevent my map
> Hi,
> there are many ways to do that, combine one or more of the options
> below to achieve the result you need:
>  * set a maxExtent for your base layer
>  * set a maxResolution for the base layer,
>  * configure a resolutions or scales array for your base layer
> Regards,
> Andreas.
> On Mon, Jul 20, 2009 at 9:05 PM, <jim.meyer at concept-solutions.com> wrote:
>> Hi everyone,
>>    I had asked this question originally on June 29, 2009 and didn’t
> receive
>> a response…
>>    Currently when I zoom out to the fullest extent available on the
>> panzoombar my map shows four copies of the earth.  Is there an easy way to
>> prevent this from happening?
>>    It seems that using a ‘singleTile’ value set to true will do it.  But,
>> I’d prefer to continue to rely upon tiled images.  Are there any other
> ideas
>> out there?
>> Thanks,
>> Jim
>> James B. Meyer
>> Java Programmer
>> (703) 472-7838
>> Suite 300
>> Reston, VA 20191
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
