[OpenLayers-Users] Unselecting multiple features
Eric Lemoine eric.lemoine at camptocamp.com
Tue Jul 28 03:05:35 EDT 2009
On Mon, Jul 27, 2009 at 12:02 PM, Florian
Diederichs<florian_diederichs at hotmail.com> wrote:
> Hi all,
> I have encountered a problem with the SelectFeature-Control. I wonder if
> anybody has a workaround/patch, knows anything, or is seeing something I am
> not. Any help would be very much appreciated.
> The problems arises every time I use this function:
> select: new OpenLayers.Control.SelectFeature(
>                        kunden,
>                                onSelect: onFeatureSelect,
>                                onUnselect: onFeatureUnselect,
>                                clickout: true, toggle: true,
>                                multiple: true, hover: false,
>                                box: true,
>                                toggleKey: "ctrlKey",
>                                multipleKey: "shiftKey"
> It can also be found at http://openlayers.org/dev/examples/ - Open Layers
> Select Feature Example.
> When you first draw some points and then select the control allowing you to
> select multiple features with a box, unselecting by clicking out isn't
> working. (With "click out to unselect features" = true of course). Only when
> you click on one of the features, the others get unselected. After that,
> unselecting by clicking out works sort of.
> Because then, when you unselect by clicking out, only the feature that got
> selected last is rendered as unselected, the others remain in their
> graphical state of being selected. Although they aren't selected, at least
> they are not in the selectedfeatures array of the layer.
> I wonder if anybody has a workaround/patch, knows anything, or if i'm just
> doing something wrong. Help would be very much appreciated.
Hi. I know what's going on: when selecting features by drawing a box
the feature handler does not participate in the selection so it never
triggers the clickout callback. I don't see any other way than faking
the feature handler, see the patch attached to this email.
Cheers
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090728/2bf954e8/selectfeature.bin
