[OpenLayers-Users] Error displaying map in IE8 - VML.js
soatley shawn at niagarafalls.ca
Wed Jul 29 12:59:23 EDT 2009
That does it!  Works like a charm and even fixes another issue I was having
with adding vectors.
Thanks!
Andreas Hocevar-2 wrote:
> soatley wrote:
>> Should have checked my CSS before posting that mesage.....
>> Here is what I already have defined in for my map object:
>> #map
>> 	position: absolute;
>> 	width: 100%;
>> 	height: 100%;
>> 	top: 0px;
>> 	left: 0px;
> Add
> html, body {
>     width: 100%,
>     height: 100%
> Andreas.
>>> soatley wrote:
>>>> In case anyone else runs into this, I found out that after the map is
>>>> created, it sometimes doesn't set a height or width value in the
>>>> map.size
>>>> property.  Here's my fix which seems to work quite nicely:
>>>>  map = new OpenLayers.Map('map', options);
>>>> if (isNaN(map.size.w) || isNaN(map.size.h)) {
>>>>             map.updateSize();
>>> You can also make sure that the container where you render the map in
>>> (in your snippet a div or whatever element with id 'map') has a width
>>> and height style before you create the map object.
>>> Regards,
>>> Andreas.
>>>> Shawn
>>>> soatley wrote:
>>>>> I have a feeling I am running into the same issue here.  I am using
>>>>> Revision 9492 and the problem I encounter is the Invalid Argument
>>>>> error
>>>>> when adding vector layers to the map.
>>>>> I have tried it on IE 7 (Win XP 32 bit) and IE 8 (Vista 64, in
>>>>> compatability mode).  IE 8 on Vista not in compat. mode works fine.
>>>>> It seems to be very similar to the issue with Ticket 1910 from what I
>>>>> can
>>>>> tell....  Setting up an IE breakpoint on line 600 of OpenLayers.js it
>>>>> breaks where the variables w and h are assigned because this.size.w is
>>>>> NaN.  If you were to look at the VML.js file, it is in the area of
>>>>> line
>>>>> 154.
>>>>> Does anyone have any new information or a way I can work around this?
>>>>> Shawn
>>>>> Christopher Schmidt-2 wrote:
>>>>>> On Thu, Jun 18, 2009 at 10:23:15AM -0700, palewire wrote:
>>>>>>> I've encountered some IE8 errors too. Here's the paste from what the
>>>>>>> browser
>>>>>>> gives you. Is there anything I can do to help out?
>>>>>> What SVN version is this with? This should only have been fixed in
>>>>>> the
>>>>>> last few commits.
>>>>>> -- Chris
>>>>>>> Webpage error details
>>>>>>> User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1;
>>>>>>> Trident/4.0)
>>>>>>> Timestamp: Thu, 18 Jun 2009 17:21:04 UTC
>>>>>>> Message: Invalid argument.
>>>>>>> Line: 793
>>>>>>> Char: 110
>>>>>>> Code: 0
>>>>>>> URI: http:// ... /openlayers/OpenLayers.js
>>>>>>> Asle Benoni wrote:
>>>>>>>> Sorry Christopher and others. That was a bad one from me. I did't
>>>>>>>> like
>>>>>>>> my attitude there.
>>>>>>>> Of course I will test it since I had the problem just now. Glad you
>>>>>>>> pointed that out since I am always so glad and amazed at people
>>>>>>>> here
>>>>>>>> just helping out ;-)
>>>>>>>> Hope I can contribute also.
>>>>>>>> /asle
>>>>>>>> Den 12. juni. 2009 kl. 16.01 skrev Christopher Schmidt:
>>>>>>>>> On Fri, Jun 12, 2009 at 03:52:54PM +0200, Asle Benoni wrote:
>>>>>>>>>> Thanks Kenneth, the compatibility hack works fine. I would rather
>>>>>>>>>> not hack
>>>>>>>>>> VML.js but I see this hack is newer than the one I tried. As long
>>>>>>>>>> as the
>>>>>>>>>> quickfix works I am satisfied. But would like to know if some
>>>>>>>>>> have
>>>>>>>>>> success
>>>>>>>>>> with it and if it is included in future OL release.
>>>>>>>>> It can't be included in a future OL release until people test it.
>>>>>>>>> If
>>>>>>>>> you're unwilling to test it, the chances it will be included
>>>>>>> decrease.
>>>>>>>>> Please help test it if you care about it.
>>>>>>>>> -- Chris
>>>>>>>>>> /asle
>>>>>>>>>> 2009/6/12 Andreas Hocevar <ahocevar at opengeo.org>
>>>>>>>>>>> Hi,
>>>>>>>>>>> On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
>>>>>>>>>>> A/S<ks at geograf.dk> wrote:
>>>>>>>>>>>> Note sure what the actual problem is, but there are notes that
>>>>>>>>>>>> the patch
>>>>>>>>>>>> does not solve all issues.
>>>>>>>>>>>> There is a nother fix mentioned, namely the one in comment #20:
>>>>>>>>>>>> http://trac.openlayers.org/ticket/1910#comment:20
>>>>>>>>>>>> This effectively places IE8 in IE7 compatibility mode, and it
>>>>>>>>>>>> works.
>>>>>>>>>>>> Although it's not the correct long term solution, you can use
>>>>>>>>>>>> it
>>>>>>>>>>>> until
>>>>>>>>>>>> the issue is fixed more permanently.
>>>>>>>>>>> The latest patch [1] should fix all vector layer issues in IE8.
>>>>>>>>>>> It
>>>>>>>>>>> would be nice to get some feedback if this is really the case.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Andreas.
>>>>>>>>>>> [1]
>>>>>>> http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
>>>>>>>>>>> Andreas Hocevar
>>>>>>>>>>> OpenGeo - http://opengeo.org/
>>>>>>>>>>> Expert service straight from the developers.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Users mailing list
>>>>>>>>>> Users at openlayers.org
>>>>>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>>>>>> Christopher Schmidt
>>>>>>>>> MetaCarta
>>>>>>>> Users mailing list
>>>>>>> View this message in context:
>>>>>>> http://n2.nabble.com/Error-displaying-map-in-IE8---VML.js-tp3061276p3114656.html
>>>>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>>>>> Users mailing list
>>>>>> Christopher Schmidt
>>>>>> MetaCarta
>>>>>> Users mailing list
>>> Andreas Hocevar
>>> Users mailing list
> Andreas Hocevar
> Users mailing list
View this message in context: http://n2.nabble.com/Error-displaying-map-in-IE8---VML.js-tp3061276p3351159.html
