[OpenLayers-Users] ZoomBox Pan in two Mapdivs at the same time
Alexandre Dube adube at mapgears.com
Thu Jul 30 07:56:07 EDT 2009
  Assuming your 'main' map is oMap and your 'second' map (that follows
the main) is oMap2, the below code should do what you seek :
        oMap.events.register("moveend", null, function(e)
{oMap2.panTo(e.object.getCenter())});
        oMap.events.register("zoomend", null, function(e)
{oMap2.zoomTo(oMap2.getZoomForExtent(e.object.getExtent(), true))});
Regards,
Alexandre
Rahn Hanno (rahn) wrote:
> Hello list,
> I have a problem with the zoomBox.
> In my Project I have two different map windows. The maps show the same
> but in different times. The Geometries are polygons.
> Now I try to realise a rectangle zoom with a button. For this I use
> the NavToolbar Control.
> This works fine for the first window. But now I will use it for the
> second window in the same time. If I zoom into the first map, then the
> second map should zoom in to the same center, zoomlevel, usw..
> The Pan should work for both maps, too.
> I will only use one button for both maps.
> Perhaps somebody can help me. Sorry for my bad english and a lot of
> thanks for your help.
> Greetings
> Hanno Rahn
> Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
> ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und
> Natürliche Ressourcen
> Fachstelle Geoinformatik
> Grüental, Postfach CH-8820 Wädenswil
> Tel +41 (0)58 934 5592
> Fax +41 (0)58 934 5580
> hanno.rahn at zhaw.ch
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
