[OpenLayers-Users] Pass layers array to php with json
sendeman martijnsendenspam at gmail.com
Fri Jul 31 05:59:31 EDT 2009
Hi All,
I'm trying to load some php into a div in my mapping application through a
http://docs.jquery.com/Ajax/load#urldatacallback jQuery load function .
This works just fine, but now I want to pass all the maps layers to the php
script, so the php script can use some of the layer properties (name, id,
visibility, etc.)
I think I have to use json to serialize layer information, but I'm not at
all sure how to do this in openlayers. I tried:
[CODE]
var layers_json = openlayers.format.json.write(map.layers);
jQuery("#modules").load("/geoviewer/includes/legend.php", {layers:
layers_json});
And in the php:
if (isset($_REQUEST['layers'])) {
  $layers = json_decode($_REQUEST['layers']);
for ($intCounter = 0; $intCounter < count($layers); $intCounter++) {
  echo($layers[$intCounter]->{'name'});
[/CODE]
However, this doesn't work at all. :-)
Could someone get me on track with this?
Thanks a lot in advance for any help! It would be greatly appreciated.
Best regards,
Martijn Senden.
View this message in context: http://n2.nabble.com/Pass-layers-array-to-php-with-json-tp3361638p3361638.html
