[OpenLayers-Users] TMS Tileorigin property bug?
Frank Broniewski brfr at metrico.lu
Tue Jun 2 05:10:33 EDT 2009
Hello list,
I am trying to align a tiled map I got to a national reference system. Things
are partially working, but I have some alignment problems. Browsing through
the docs, I found the tileOrigin property of the TMS Layer. But there seems to
be no effect when setting this.
Looking through the TMS.js code, I found that the getURL function uses
tileOrigin.lon and tileOrigin.lat as property accessors. But when I set the
tileOrigin with OpenLayers.Pixel(), there is only a x and y property accessor.
This seems to be a bug. It should probably be an OpenLayers.LonLat object ...
Just wanted to mention that ... :-)
Frank
Frank Broniewski
Metrico s.àr.l. ( http://www.metrico.lu )
36, rue des Romains
L-5433 Niederdonven
Luxembourg
Fon: +352 26 74 94 28
Fax: +352 26 74 94 99
