[OpenLayers-Users] How to define a custom Proj4js.defs["myown"]?
    Mike Adair
    madair at dmsolutions.ca
    Tue Jun  2 13:51:08 EDT 2009
It should be something like:
+proj=stere +lat_0=90 +lat_ts=60 +lon_0=263 +k=??? +x_0=3450000
+y_0=7450000 +ellps=WGS84 +datum=WGS84 +units=m
I'm not positive about the lon_0 param, and the k param is a ratio of
resolution at standard parallel to another resolution value but I'm not
sure what that other value is.  To test to see if the above works, set
k=1.0 and we can look up what the correct value for K should be.
Mike Adair
stephane.poirier at usherbrooke.ca wrote:
> Hi All,
> How to define a custom Proj4js.def["myown"] when it is not in
> http://spatialreference.org/ref
> but when I have the following projection parameters?
> lon_0??       >
> polar_stereographic:straight_vertical_longitude_from_pole = 263.f ;
> lat_ts           > polar_stereographic:standard_parallel = 60.f ;
> x_0             > polar_stereographic:false_easting = 3450000.f ;
> y_0             > polar_stereographic:false_northing = 7450000.f ;
> lat_0           > polar_stereographic:latitude_of_projection_origin =
> 90.f ;
> proj=stere   > polar_stereographic:grid_mapping_name =
> "polar_stereographic" ;
> polar_stereographic:resolution_at_standard_parallel = 50000.f ;
> For example, using
> http://spatialreference.org/ref/epsg/32661/proj4js/ for universal
> polar stereographic (which is usefull when used for area above the 60
> degrees north ), I get Proj4js.defs["EPSG:32661"] = "+proj=stere
> +lat_0=90 +lat_ts=90 +lon_0=0 +k=0.994 +x_0=2000000 +y_0=2000000
> +ellps=WGS84 +datum=WGS84 +units=m +no_defs";
> Regards,
> Stephane
> Stephane Poirier, M.Sc. Optics Physics
> Remote Sensing Research Professional
> University of Sherbrooke, QC, Canada
> Stephane.Poirier at USherbrooke.ca <mailto:Stephane.Poirier at USherbrooke.ca>
> http://www.usherbrooke.ca/cartel
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
