[OpenLayers-Users] Refresh vectorLayer
after de/activateclusterStrategy
Vivien Deparday
vivien.deparday at gmail.com
Wed Jun 3 18:06:55 EDT 2009
If you are interested, I had started to work on some basic toggling
on/off of the clustering: http://trac.openlayers.org/ticket/1974
I was planning to work on it again when the 2.8 was out and when one of
my project is done but if you have a better way to do this, you can
submit a patch on this ticket.
Cheers,
Vivien Deparday
Heidt, Christopher M. wrote:
> i just extended the cluster strategy to get what i was looking for.
> Might be helpful to others.
> [JAVASCRIPT]
> //This allows me to addFeatures to my layer without deleting the
> current ones,
> //also supports toggling activity without clearing the cache so that
> deactivating
> //the strategy will reapply the features to the layer unclustered,
> //and activating will cluster them again
> OpenLayers.Strategy.AppendableCluster =
> OpenLayers.Class(OpenLayers.Strategy.Cluster, {
> //activation now immediatly clusters
> activate: function() {
> var activated = OpenLayers.Strategy.prototype.activate.call(this);
> if(activated) {
> this.layer.events.on({
> "beforefeaturesadded": this.cacheFeatures,
> "moveend": this.cluster,
> scope: this
> this.cluster(); //<--
> return activated;
> //deactivating clears clusters and adds the features directly
> //DOES NOT CLEARCACHE
> deactivate: function() {
> var deactivated =
> OpenLayers.Strategy.prototype.deactivate.call(this);
> if(deactivated) {
> this.layer.events.un({
> scope: this
> this.layer.destroyFeatures(this.layer.features); //<--
> this.layer.addFeatures(this.features); //<--
> return deactivated;
> //cacheFeatures now appends new features to the current cache
> cacheFeatures: function(event) {
> var propagate = true;
> if(!this.clustering) {
> if(this.features === null){
> this.features = [];
> this.features =
> this.features.concat(event.features); //<--
> this.cluster();
> propagate = false;
> return propagate;
> //added an !event check to the second if to enable forced clustering
> cluster: function(event) {
> if((!event || event.zoomChanged) && this.features) {
> var resolution = this.layer.map.getResolution();
> if(!event || resolution != this.resolution ||
> !this.clustersExist()) {
> this.resolution = resolution;
> var clusters = [];
> var feature, clustered, cluster;
> for(var i=0; i<this.features.length; ++i) {
> feature = this.features[i];
> if(feature.geometry) {
> clustered = false;
> for(var j=0; j<clusters.length; ++j) {
> cluster = clusters[j];
> if(this.shouldCluster(cluster, feature)) {
> this.addToCluster(cluster, feature);
> clustered = true;
> break;
> if(!clustered) {
> clusters.push(this.createCluster(this.features[i]));
> this.layer.destroyFeatures();
> if(clusters.length > 0) {
> if(this.threshold > 1) {
> var clone = clusters.slice();
> clusters = [];
> var candidate;
> for(var i=0, len=clone.length; i<len; ++i) {
> candidate = clone[i];
> if(candidate.attributes.count <
> this.threshold) {
> Array.prototype.push.apply(clusters,
> candidate.cluster);
> } else {
> clusters.push(candidate);
> this.clustering = true;
> this.layer.addFeatures(clusters);
> this.clustering = false;
> this.clusters = clusters;
> CLASS_NAME: "OpenLayers.Strategy.AppendableCluster"
> [/JAVASCRIPT]
> -----Original Message-----
> From: users-bounces at openlayers.org on behalf of Heidt, Christopher M.
> Sent: Wed 6/3/2009 3:36 PM
> To: users at openlayers.org
> Subject: [OpenLayers-Users] Refresh vectorLayer after
> I use a clusterStrategy by default, but I have a button that lets the
> user toggle it off.
> Is there a way to refresh the layer so that it can redraw with/without
> clusters?
> I've tried:
> [JS]
> if(pressed){
> clusterStrategy.activate();
> else{
> clusterStrategy.deactivate();
> clusterStrategy.clearCache();
> vectorLayer.redraw();
> [/JS]
> But that was not helpful.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
