[OpenLayers-Users] Zindex of vectors
Brad Spencer brad at cubewerx.com.au
Fri Jun 5 09:30:12 EDT 2009
Christopher,
I managed to sort this out myself. I admit it probably was a sledgehammer to
crack a nut!
After I loaded the points as circles on a vector layer with its styleMap &
Popups, I then applied the following 2 lines to make sure that the vector
layer was always above my other layers and that the popup layer was above
the vector layer.
map.Z_INDEX_BASE['Popup'] = 20000;
userMarkers.setZIndex(map.Z_INDEX_BASE['Popup'] -1);
I'm sure its not the most elegant way to do this but it works just fine for
my app.
Cheers, Brad...
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Friday, June 05, 2009 10:19 PM
To: Brad Spencer
Cc: openlayers users
Subject: Re: [OpenLayers-Users] Zindex of vectors
On Fri, Jun 05, 2009 at 06:17:14PM +1000, Brad Spencer wrote:
> List,
> I have moved from markers to vectors for a bunch of reasons. However, when
I
> load some vector circles from an external csv file with  framedCloud popup
> bubbles associated, the popups appear on mouseover as planned but are
below
> all the points. Is there anyway to control the zindex of the Popups?
The z-index of popups is always above the markers. If this is not
happening, there must be something different/special about your setup
that is different from other OpenLayers maps. Is there a demonstration
of this problem online?
Regards,
Christopher Schmidt
MetaCarta
