[OpenLayers-Users] WMSGetFeatureInfo not working as expected with
ESRI ArcGIS server
Linde Ackermans
roselinda.ackermans at ec.europa.eu
Mon Jun 8 08:51:39 EDT 2009
Server = ArcGIS Server 9.3
Code :
var q1 = new OpenLayers.Layer.WMS("q1",
"http://server/arcgis/services/s1/mapserver/wmsserver",{layers: "0"});
var q2 = new OpenLayers.Layer.WMS("q2",
"http://server/arcgis/services/s1/mapserver/wmsserver",{layers: "1"});
var q3 = new OpenLayers.Layer.WMS("q3",
"http://server/arcgis/services/s2/mapserver/wmsserver",{layers: "0"});
var infoCtl = new OpenLayers.Control.WMSGetFeatureInfo({
layers: [q1,q2,q3],
title: 'Click on the map to get information on layers',
queryVisible: true,
infoFormat: 'application/vnd.ogc.wms_xml'
var infoOpts = {iconCls: 'queryonclick',toggleGroup: 'map'};
infoCtl.events.register("getfeatureinfo",map,showInfo);
toolbar.addControl(infoCtl, infoOpts);
function showInfo(evt) {
I assume this works for most map-servers, because their wms url points to a
kind of 'pool' for all layers, but ArcGIS server has a different url to use
for each different service ... as you can see in the definition of the
layers q1 and q2 (same service) and q3 (other service).
On mouse click, this is sent to the server :
http://server/arcgis/services/s1/mapserver/wmsserver?service=WMS&version
=1.1.0&request=GetFeatureInfo&layers=0,1&query_layers=0,1&styles=,&bbox=2397751.148714%2C2793354.476705%2C6652248.851286%2C3941645.523295&srs=EPSG%3A3035&feature_count=10&x=289&y=160&height=217&width=804&info_format=application%2Fvnd.ogc.wms_xml
So, layers of the same service are correctly combined ( 0 and 1 ), but
layers from other, additional services are lost.
Is this the normal behaviour ? ( AGS being a bit 'abnormal' ... )
And if so, how do I solve/workaround this best ?
Linde
View this message in context: http://n2.nabble.com/WMSGetFeatureInfo-not-working-as-expected-with-ESRI-ArcGIS-server-tp3042742p3042742.html
