[OpenLayers-Users] Layers not loading data
Kevin Galligan kgalligan at gmail.com
Mon Jun 8 23:06:26 EDT 2009
Did all this stuff, and it looked like the mapping was off, which was
pretty frustrating.  The data was showing up, but it was consistently
off by about 10 miles south.  In a last ditch effort, I tried a
different source for the projection info for postgis.  That fixed it.
Now the data maps up right on top of where its supposed to.  Really,
really sweet!
Here's the right one...
http://www.easywms.com/easywms/?q=en/node/3592
Look towards the bottom for 'INSERT into spatial_ref_sys (srid, auth_...'
The one that didn't quite work out was here...
http://spatialreference.org/ref/sr-org/6627/
Linked from here...
http://veryspatial.blogspot.com/2008/12/use-open-street-map.html
On Mon, Jun 8, 2009 at 10:49 AM, Kevin Galligan<kgalligan at gmail.com> wrote:
> That pretty much covers it.  Thanks!
> On Mon, Jun 8, 2009 at 10:17 AM, Heidt, Christopher
> M.<CHRISTOPHER.M.HEIDT at saic.com> wrote:
>> sphericalMercator is probably the biggest issue people have when using
>> google layers.
>> http://docs.openlayers.org/library/spherical_mercator.html
>> -----Original Message-----
>> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> On Behalf Of Kevin Galligan
>> Sent: Monday, June 08, 2009 10:11 AM
>> To: users at openlayers.org
>> Subject: [OpenLayers-Users] Layers not loading data
>> I have a feeling I'm going to see the issue tonight when I take another
>> look at the code, but I thought I'd send this now and see if there's
>> maybe something I'm missing that somebody knows off hand.
>> I have a map with an open street map layer on the bottom, and a wms
>> layer on top that points to a geoserver/postgis data set.  When I run
>> the demo map in geoserver's control panel, the data displays fine.  In
>> my map, however, the layer never shows up.  In fact, the data is never
>> requested for the layer.  It seems like the map doesn't think its inside
>> the display area for the layer and doesn't request any data.
>> when I zoom out significantly, like global level, it starts requesting
>> data.
>> The data was converted to the "google" projection, and I tell the map
>> and layer to explicitly use that projection, and using the demo layer,
>> it seems like it is in fact in that projection.  However, since it
>> starts grabbing data at the global level, I think its internally using a
>> bounding box in standard lon/lat ranges.  I can't post the code until
>> tonight, but I'm sending this now in case somebody has an obvious thing
>> that I'm missing.
>> Thanks in advance,
>> -Kevin
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Kevin Galligan
> www.kagii.com
Kevin Galligan
www.kagii.com
