[OpenLayers-Users] Popup can not be closed when zooming
Alexandre Dube adube at mapgears.com
Tue Jun 9 08:15:36 EDT 2009
  Just put a break point on this line :
            if (*feature.popup[]*= null){
 Then, using the "script" tag and at the right the "watch" tab, you will
then be able to see all variables and object currently available,
including "this" (which should be your map object).
  There's plenty of tutorials on the web that could help.  Just google
"firebug how to use" for example.
Best of luck,
Alexandre
Asle Benoni wrote:
> Ok. Not really sure where to put this, when does it fire?
>         function checkPopup(feature) {
>             feature.popup.destroy();
>         map.events.register("moveend", map, checkPopup);
> I have FireBug but do not really know what to check :-(
> Forgive my small knowledge here.
> /asle
Alexandre Dubé
Mapgears
www.mapgears.com
