[OpenLayers-Users] WMS 1.3.0 with Tiling problem
Sarawut Ninsawat sarawut.map at gmail.com
Thu Jun 11 02:57:22 EDT 2009
Hi, Arnd
I also think it is a problem of northing and easting change in WMS 1.3.0
After I got your comment then I carefully check my non-tile map. It
shows with wrong direction also.
Best regards
Sarawut
Arnd Wippermann wrote:
> Hi Sarawut,
> With WMS 1.3.0 the order for coordinates has changed
> &BBOX=lat0,lon0,lat1,lon1
> instead with WMS 1.1.1
> &BBOX=lon0,lat0,lon1,lat1
> OpenLayers doesn't support WMS 1.3.0. The bbox-values have to be replaced as
> above in the wms request.
> The reason for your funny tiled map is, that you set the bounds like
> lat0,lon0,lat1,lon1, but OL interpretes them as lon0, lat0, lon1, lat1 and
> generates therefor the request for the wms tiles. If you set your bounds in
> the right way, you get no tiles.
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Sarawut Ninsawat
> Gesendet: Donnerstag, 11. Juni 2009 04:27
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] WMS 1.3.0 with Tiling problem
> Hi all,
> I am trying to make a request for WMS 1.3.0 by following some recommend in
> mailing list.
> It was success. But the mosaic of tile image is wrong. As you may seem from
> below link (it turn up/down and left/right I think)
> http://geodata2.geogrid.org/modis/test.html
> Then I try with SingleTile is beautiful mosaic image.
> http://geodata2.geogrid.org/modis/nontile.html
> I think maybe I miss something for custom projection or extent.
> Best regards
> Sarawut
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
