[OpenLayers-Users] Google license
David Fawcett david.fawcett at gmail.com
Thu Jun 11 10:56:23 EDT 2009
Because you are using Geoserver, it may not be of much use, but there
are several examples of 'Googley' MapServer map files that could be
found by searching the MapServer listserv.  I don't know if there is
an easy way to convert between a MapServer map file and a geoserver
config file.
David.
On Thu, Jun 11, 2009 at 9:08 AM, Kevin Galligan<kgalligan at gmail.com> wrote:
> How would one do this?  I'm using openstreetmaps now, and things look
> OK, but I think people are used to how google maps looks.  Plus the
> color scheme is a little "warmer".  OSM is very blue/gray.
