[OpenLayers-Users] getDataExtent() only working on part of data
of layer
Jan Martin
janmartin3 at googlemail.com
Thu Jun 11 12:49:56 EDT 2009
Hi Andreas,
thanks for your help.
I hope I changed my file right, but unfortunately its not working:
http://mybestprojects.com/data/test5/test5.html
Also I have no clue how to implement Format.GPX::read
There are no results of anybody using it when googling for it.
Can't be can it?
Jan
On Thu, Jun 11, 2009 at 6:07 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> Hi Jan,
> one more thing that came to my mind: are you aware that you are
> working with two layers here? From what you wrote, it seems you think
> that you have one layer lgpx. But in fact you have two, you just use
> the same variable for both.
> You could also solve your problem with just one layer, but then you
> would have to use Format.GPX::read to get the features from both urls.
> You would also have to take care to style the features properly (red
> from one url, green from the other).
> I guess the way you chose is simpler, you just have to be aware that
> you are working with two layers.
> Regards,
> Andreas.
> On Thu, Jun 11, 2009 at 5:55 PM, Andreas Hocevar<ahocevar at opengeo.org>
> wrote:
> > Hi Jan,
> > On Thu, Jun 11, 2009 at 5:20 PM, Jan Martin<janmartin3 at googlemail.com>
> wrote:
> >> Hi all,
> >> right now getDataExtent() only considers the data added LAST (red).
> >> But I need the map to zoom in on ALL data in lgpx (green AND red).
> >> What's my error?
> > you need to take into account the dataExtent of both layers:
> > var dataExtent;
> > var setExtent = function() {
> > dataExtent = dataExtent ? this.getDataExtent() :
> > this.getDataExtent().extend(dataExtent);
> > map.zoomToExtent(dataExtent);
> > lgpx = new OpenLayers.Layer.GML
> > ("green","separated/20090607172151.gpx",{
> > projection: new OpenLayers.Projection("EPSG:4326"),
> > style: {strokeColor: "green", strokeWidth: 5, strokeOpacity: 0.8},
> > format: OpenLayers.Format.GPX,});
> > lgpx.events.register("loadend", lgpx, setExtent);
> > map.addLayer(lgpx);
> > ("red","separated/20090607110550.gpx",{
> > style: {strokeColor: "red", strokeWidth: 5, strokeOpacity: 0.8},
> > map.addLayer(lgpx);
> > Regards,
> > Andreas.
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090611/fe6b557c/attachment.html
